My Bosch Exccel 7 wont go into fast spin mode ?
    Prodigy:
    An expert who has answered 500 questions.
  • Washing Mach... Expert
  • 517 Answers
Is the filter clean
Posted on Feb 14, 2014
My Bosch wfmc2100 continues to add time to the timer and when I place it in spin mode I hear pump come on and drain but it acts like its still agitating the clothes and never Ramps to speed.
Some times if you wash large and small items the washer cannot get the clothes balanced enough to go into high spin. The washer being out of level can also cause this problem. Another issue that can cause this is the drain fluff/filter is plugged a bit and wont let enough water to the drain pump fast enough and when the timer sees that there is still water in the drum it adds more time to allow for the water to be removed. front bottom access panel will get you into the fluff/filter to clean it out. Make sure to get all the threads clean of sand and debris and use light oil to replace the cap or you will break it trying to reseal it.
Jul 29, 2016 | Bosch Washing Machines
F43. Terminal?
motor brushes on bosch machines typically last 6-7 years its the first thing to check
Mar 19, 2014 | Bosch Washing Machines
BOSCH HBL3450UC Single Oven weak/slow pre-heat
I have a Kitchen Aid convection wall oven. It takes 6 - 7 minutes to preheat to 325 degrees. You probably have a bad element. There are 2 elements.
Dec 19, 2012 | Bosch HBL3450UC Single Oven
My Bosch next 300 washer doesn't spin as fast as it did. It leaves the clothes wet and some water in the drum. No error code comes up? How do we fix it?
If the tub still moves but it's just not spinning that fast (and the water is draining out), then that means your motor control board has just started to fail and it will need to be ordered and replaced to fix the issue. If you pull the washer out and remove the back panel, there is a control board mounted to the floor under the tub. This is the motor control board and it will need to be ordered and replaced to fix the issue.
Oct 28, 2012 | Bosch Nexxt 300 Series WFMC2201UC
Bosch WFO2865GB that stops before the Spin cycle
probably not draining fast enough, check for blockages at filter, sump, outlet and plumbing
Mar 29, 2010 | Bosch Washing Machines
My bosch front loading washer on the small cycles will not spin the water out of the clothes..why?
Does it sound like the machine is spinning as fast as on longer cycles?Some machines run a slower spin speed on small cycles which can leave clothes wetter than normal. I've got this on mine and all I do is when the wash has finished I change over to the fast spin only program which then takes it to it's highest spin speed.
Jan 25, 2010 | Bosch Washing Machines
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
