Brivis heater believe its a star pro unit Have an error code 65 can anyone help Trying to put the cooler on
  • 3 Answers
SOURCE: Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Posted on May 05, 2010
  • 6 Answers
SOURCE: Error code 62 on Brivis Me20 ducted heater
Hi
Error 62 is related to hot surface ignitor (HSI)or/nglo module
you can check the resistance of the ignitor should be less than 10 oms @ 20 degrees
failing that, if you incomming suppy exceeds 270 volt will also result in error 62
Posted on May 15, 2010
Testimonial: "The error did indicate an HSI problem but it turned out to be a fault on the circuit board of the control module, thanks anyway"
potek18
  • 528 Answers
SOURCE: hi i have a brivis
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Posted on Jul 12, 2010
bunnydawg
  • 5158 Answers
SOURCE: We have a brivis error
we need you to confrm if you will that the error code you gave was not a typo. from all the information i've found so far error codes only go to about error 67
some pages to read are here
http://rework.brivis.com.au/web/BrivisInetQuest.nsf/0/2df68f5c6d0e10d5ca257059007b57ac?OpenDocument
http://www.brivis.com.au/content.cfm?content=166
Posted on Dec 27, 2010
jas247
  • 844 Answers
SOURCE: what causes a 71 error code on a brivis ducted
Welcome to FixYa!
Error Code 71 is caused by either of the following: 1. A very low setting on the controller less than 16 degs. 2. Or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
The power supply needs to be reset due to the fault being detected.
Solution:
  • Put the power supply to heater off first
  • Reset the heater panel
  • Press the button again to show EMS on
  • Then set the heater to the required temp. after turning on to the heating mode.
Thank you for using FixYa.
Have a great day.
Jas247
Posted on Jun 04, 2011
Brivis error code 62 hi
Hi Matthew,
It would seem obvious to contact the manufacturer's customer support department. http://brivis.com.au/
Aug 01, 2015 | Heating & Cooling
Brivis central heater code 65 with spanner
Are you having trouble with the code? The heater should have come with one. If you need to, call the manufacturer.
Elisa Jed ' http://www.manwill.net/heating.php
May 10, 2014 | Heating & Cooling
Brivis heater spanner showing with ho1 code 65
It is a flame loss error. Open the unit up Clean both of the flame sensors with either a file or steel wool (with the power off) then turn power back on and reset the screen to do this hold down all 3 buttons for 10 sec. there should be 2 buttons on one side and 1 on the other. hope this helped :)
Brivis zone
$900 seems like a lot for a new HSI and flame sensors :( 54 seems to be with the supply air thermistor. does the unit still operate with the error?
May 09, 2014 | Heating & Cooling
Hi I have error code 30 H1 on my Brivis heater, The problem is the fan sometime speed up itself
my power went out last night and today the heat was not working just the cooler , l turned off the main to the heater and the main power and reset the unit but is still the same
Mar 23, 2012 | Heating & Cooling
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Jul 12, 2010 | Heating & Cooling
Apr 12, 2010 | Heating & Cooling
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Brivis Heater help
These Brivis guys and girls are a rip-off. They are only out to take your money. Then can easily ask you to do just as mentioned above. And pronto all works in 3 minutes to be precise.
It is just the power supply reset required due to a fult being detected, either caused by a very low setting on the controller less than 16 degs. or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
So, put the power supply to heater off first, reset the heater panel, press the button again to shaow EMS on and then set the heater to the required temp. after turning on to the heating mode. That simple! That is if it is the error 71 HI.
Jun 01, 2008 | Heating & Cooling
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
