Question about Xerox WorkCentre M15i Laser Printer
LSU ERROR I HAVE A LASER PRINTER XEROX M15I WHEN I TURN IT ON IT SHOWS ME LSU ERROR SO I WOLD LIKE TO KNOW HOW I CAN RESORVE THAT PROBLEM.THANKS
  • 2072 Answers
SOURCE: lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Thanks.
Posted on Dec 31, 2007
SOURCE: LSU Error
Hi Dear
I am facing LSU Error on my Xerox workstation PE 220
I am not able to do anything, please let me wat to do
i have lot of work penindg
urs
mujahid
Posted on Oct 13, 2008
  • 65 Answers
SOURCE: Xerox M15 PCL6 error
I would go to the xerox website and try downloading the PCL5e driver. It works just as well and even better in most cases. I hope this helps.
Posted on Dec 07, 2008
Dadofmykids
  • 25 Answers
SOURCE: Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Posted on Apr 07, 2009
Smith-alone
  • 360 Answers
SOURCE: xerox M15i has a paper jam 2 error, how to fix
Hi, open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Take care
Posted on Jul 19, 2010
THERE IN SOME LSU ERROR SHOWING WHATS A SOLUTION
LSU stands for Laser Scanning Unit. An LSU Error means there is a problem with your laser scanner, the part that helps create your prints. There could be a problem with the laser, polygon mirror, sensor, etc. that needs to be fixed. In the User's manual it says to:
Turn power off and wait 10 seconds. Turn power on. If the problem persists, call for service.
If powering it off then on fails, you will need to have it looked at by a service tech to fix it. It may need a new laser unit or control board.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 30, 2010 | Xerox WorkCentre M15i Laser Printer
LSU error
LSU error means a laser failure or a power failure.its just like a problem like a computer getting hang.So in this scenario u need to switch off the machines and restart it after 5 min.
Nov 26, 2010 | Xerox WorkCentre M15i Laser Printer
Xerox M15i has a paper jam 2 error, how to fix
Take care
Jul 19, 2010 | Xerox WorkCentre M15i Laser Printer
LSU Error keeps showing
LSU stands for Laser Scanner Unit. Depending on the model this should come up only if the services used required scanning such as copy, fax sending, scanning.
nevertheless if this is a continuous message you might need to check the connectors within the scanner which I advise an field call.
Apr 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
LSU error message
That is the Laser unit. Not good. There may be a service reset process but you'll have to send or call it in.
Mar 18, 2009 | Xerox Phaser 3200MFP/N Laser Printer
Dec 07, 2008 | Xerox WorkCentre M15i Laser Printer
Xerox m15i
The heat rod is bad in the fuser.
You need to replace the fuser.
Look at this site.
https://www.partsdrop.com/store/
May 28, 2008 | Xerox WorkCentre M15i Laser Printer
Lsu error
Thanks.
Dec 27, 2007 | Xerox Phaser 8500/DN Printer
Xerox WorkCentre M15i Laser Printer Logo
46 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
