Question about Zebra Z4M Printer
Remove paper from cutter zebra z100 xi4 - Zebra Z4M Printer
3 Suggested Answers
SOURCE: my zebra 4M+ get me a cutter jammed status
Sometimes debris builds up in the bottom of the cutter assembly preventing the cutter from going all the down. There is a switch inside the cutter which trips the "jammed" error if the cutter can't go all the way down. The cutter can be removed and disassembled to remove the problem. Caution should be exercised. There are washers and springs on the cutter face plate guide screws which have to be removed.
Posted on May 20, 2009
ozztech
  • 285 Answers
SOURCE: hi i have problem with my zebra m4plus cuter the
select the TEAR OFF mode on the same seting that you have the Cutter.
Posted on Nov 13, 2010
We have a Zebra 110 Xi4 that gives me the error printer not accessible...I have tried uninstalling and reinstalling the printer and still get the same issue
Depending on the type of connection you are using it could be a Main board issue or Ethernet card failing. Make sure it is a printer issue and not a problem with cabling, IP addresses or your PC before replacing any parts. (ignore pictures FixYa is grabbing the wrong ones)
Main Board ZEBRA P1004273 MAIN LOGIC 8MB XI4 SERIES New
Ethernet card ZEBRA 79501 011 KIT INT PRINT SERVER 10 100 Refurbished
Sep 27, 2017 | Zebra Office Equipment & Supplies
Feed option not working but printer ready.
Dear jafar,
just first you conform there is no paper jams in your printer then only i will tell it is motor issue///
Jun 18, 2014 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
Zebra 110xi4 labels jam going into the cutter
This is usually related to the setup of the printer. Check that there is no backfeed set up, and that the settings are on for calibration on head close.
Oct 10, 2012 | Zebra 110Xi4 203DPI 10100 CUTTER W TRAY...
Zebra zm 600 cutter problem no stop working
change the seting from "CUTTER" to Tear off
Mar 08, 2011 | Zebra Printer 140-751-00000
Cutter jammed
if you take the side off, and then the power supply, you will see a sensor and a flag, check for wear / damage. sometimes the allen bolt that holds the lower cutter linkage can come loose. try cleaning the sensor. also the connections from the cutter board need cleaning with ipa. if that doesnt solve the issue, you can take the cutter off, remove the silver plate and remove any label debris. if all this fails to solve the problem you will probably require a cutter board or sensor.
Jun 24, 2009 | Zebra 105SL Thermal Label Printer
Zebra 140xiIIIPlus w/ attached cutter, cutter will not cut labels
For the cutter to work it is necessary to instruct the printer to "Use the cutter" This setting is usually accessible in the printer driver. Your label program interacts with the printer driver. Ensure that the cutter option is selected in the printer driver.
Apr 02, 2009 | Zebra 140XiIIIPlus Direct Thermal-Thermal...
My zebra 4M+ get me a cutter jammed status
Mar 26, 2009 | Zebra Z4M Printer
Ribbon and media sticking together bypassing cutter
Make sure that the ribbon options are turned on the printer. If you recently switch from using thermal stock which doesn't require a ribbon, then it needs to be turned on in the control panel of the printer.
If it is on, remove the ribbon cartridge from the unit and manually turn the wheels to make sure it is moving freely.
Nov 20, 2008 | Zebra 105SL Thermal Label Printer
Zebra Z4M Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
