Question about Fossil Grimm FS4154 Watch
Replacement pin for the case !
Having hard time finding pin for case ?
How to remove the band on the Invicta venom reserve
If you are talking about removing the entire band from the case, the Venom uses 2 spring-tension pins on each side, both of which must be released from their holes in the case to free the band. it is a tricky, hard to see procedure, even for a jeweler, but it can be done. I recommend taking the Venom to the jeweler the first time and letting them show you what the attachment looks like. This would make it easier for you to try yourself in the future without scratching the case or becoming too frustrated.
If you must try this yourself, be patient and use a small tool like a mini screwdriver to release the first pin via the small gap on the underside of the band, and then look for the 2nd pin which is further back. A small flashlight may help you see the pins. Then repeat on the opposite end of the band.
Putting the watch band back on the case is somewhat easier, still requiring patience and several tries. Don't lose or damage the pins.
Sep 29, 2015 | Invicta Watches
Tip
How to remove or add links to watch bracelets.
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done!
on Mar 07, 2010 | Watches
Tip
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
on Jan 06, 2010 | Watches
Removing ceramic links from watch
Apr 02, 2011 | Peugeot 160GY Wrist Watch
How do I remove links
Jan 14, 2010 | TechnoMarine Ceramique Watch TCB02C
Trying to remove watch links
Jan 09, 2010 | Invicta Pro Diver 9321 Wrist Watch
Having trouble removing pin from men's Ebel 1911
Watchmakers are using special pin removing tools and punches. You can find them on Ebay. If you have pins you can not damage threads as pins do not have any threads - they are friction fitted. Punch must be the size of the pin end you can see. Some pins come out easily, some quite hard, so, use appropriate strength to drive pins out. In case if there are screws - use small screwdriver to fit in the slotted screw end and unscrew the screw.
Rate me, plz.
Jan 06, 2010 | Ebel E Type 9157C11/5716 Wrist Watch
How do you remove the back of a Bulove watch to change the battery
There is a reason why Bulova watches cost so much when you need to replace the battery....it's DIFFICULT! You can try the following, but I would HIGHLY recommend having a jeweler replace it for you. At one time Walmart did it for next to nothing, but I don't know if they do Bulova watches at this time, but it costs nothing to call them.
Try this AT YOUR OWN RISK:
The best choice for removing a threaded caseback is to use a "caseback removal tool", which consists of two or three adjustable "pins" attached to a handle (most WalMarts sell a two-pin tool in their jewelry department, and you can purchase a better three-pin tool from several vendors on eBay). To use it, start by placing the watch face-down on a padded surface (to avoid scratching the crystal). Adjust the pins so that they very snugly fit into the notches cut into the caseback; if you don't, the pins can jump out when you try to use it and scratch the watch. Place the tool over the caseback and engage the pins into the slots; then, holding the watch steady with one hand and the tool in the other, give the tool a counterclockwise turn to loosen the back (it may take a lot of force to do this, especially if this is the first time the battery is being replaced). Once the caseback is loosened (usually about 1/4 to 1/2 turn), remove the tool and finish unscrewing the back by hand to avoid scratching the watch. Be careful as you remove it as some watches use a very thin O-ring on the back to make a watertight seal.
Afer replacing the battery and ensuring the watch is running properly again, carefully inspect the surface of the case and the threading on the caseback and remove any dust or grimy deposits with a soft cloth. Then, place the caseback onto the case, being careful to align the O-ring or other seals, as well as the caseback threads (tip: to ensure the threads are lined up, place the back on the watch and turn it counterclockwise about 1/2 turn or until you feel the ends of the threads "fall" into place). Screw the caseback down as far as possible by hand, then use the removal tool to tighten it the rest of the way.
Oct 03, 2009 | Bulova Crystal 96L000 Watch for Women
Adjust watch band for Seiko 7T94 Stanless Steel Band
First you have to find out what sort of pins or even screws are used to keep links together.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
Job done!
Don't forget to rate, please.
Apr 04, 2009 | Seiko Watches
Can't set the time or adjust the ******** crystal Starck PH-1100
Take a VERY close look at yor watch and you should notice a few tiny buttons. One of them should correspond to MODE, another to SET and so on- depends on how many your watch has.
Use a pin or a needle to push them and find out the settings procedure.
If you cant find buttons on the case sides, examine case back. They can be hidden between the lugs, so, the strap should be taken off.
Remember- there are no watches in existance without adjustment features. Even atomic clock needs to be adjusted after a few million years of work:))
Good luck.
Arthur
Dec 16, 2008 | Fossil Watches
Fossil Grimm FS4154 Watch Logo
16 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
