Question about Gaggenau Ovens
Gaggenau Steam Oven: 'No water' indication
Hello, my Gaggenau steam oven BS251110 shows 'No water' symbol, while the water tank is full. I checked the magnets in the water tank to move freely, not sticking to the tank body. I am to blame the magnet valve. However, when switched on via service menu, the valve successfully passes water to the evaporator plate. Should I nevertheless replace the magnet valve, or is it the pc board, switching the valve, that is faulty? Thank you!
  • Yasha
    Yasha Feb 22, 2014
    It was the water tank that needed replacement. The question is closed.
3 Suggested Answers
SOURCE: miele steam oven keeps wanting to be descaled after descaling!
Ours does too. Did you ever get it fixed?
Posted on Feb 21, 2010
SOURCE: Gaggenau Ed 220/221 Error Code F 70
I had the same fault F70. Poured several liters boiling water no result. I decided to take the oven out the kitchen and put on the table. Be carefull, its edges are sharp. You need to disconnect water supply, first close the tap, then remove the water pipe from the oven by hand. Remove also the drain pipe from the sewage connection. You cannot detach it from the oven. Unplug power supply. Then start unscrewing the top panel. Once removed you can unscrew also the side panel left side (by looking at the oven from the front door side) and finally remove the back panel. You will need a special screw driver as the screws are star type.
I found out that there was some little water on the bottom panel of the oven. There is a safety sensor which is in contact with the bottom panel on the left side of the oven near the electronic board.
If this get wet, the faul code F70 appears.
Also some water was in the hole of the level sensor in the pump chamber next to the other sensor (white plastic box)
So dry all the water with the help of kitchen paper and finally with hair dryer.
Put back all teh parts and voila', it works again.
Posted on Sep 15, 2010
I have a steam oven. the pitcher is full and in place but the symbol is on that indicates it needs water so how do we remedy this.
as there is no make listed so we could search for the problem I can only guess a sensor has gone bad
Feb 28, 2016 | Ovens
Won't start key symbol flashing
So do you need a manual for operating it ?
Oct 06, 2008 | Gaggenau EB290 Electric Single Oven
Oven doesn't give steam but it does reach the temp.how can i fix that?
First locate the water solenoid valve. Disconnect the water line to the inlet side of the valve to make sure water is getting to the valve. Once that's verified, disconnect the outlet side of the valve. Activate the steam and verify that the valve opens and there's a good amount of water coming out of the valve. If no water comes out. Verify that the coil is getting energized with the correct voltage. If the correct voltage is present and you have no water coming out. Replace the solenoid. If everything is working then remove the left panel inside the oven to check for blockage in the steam manifold. The manifold consists of a pipe with several spray nozzles that spray water on rebar. Remove all the nozzles and activate the steam. Do this several times to purge any rust or debri. Clean the nozzles and replace them. You should be good to go.
Aug 25, 2015 | Baxter OV310G Mini Rotating Rack Gas Oven
My oven fills with steam and I can't bake cakes etc as they retain too much moisture
Your vents are blocked unless this is a steam clean oven. Check for continuos water drainage. Water valve could be bad. I need a model number.
Oct 26, 2013 | Ovens
I just need what the symbols means as we lost our manual.
Check this for your oven direct from Gaggenau Manual:
If need additional details, just Contact Us.
Hope this helps (remember to rating and leave an testimonial comment about this free answer).
Oct 10, 2011 | Gaggenau EB 270/271 Electric Single Oven
We have a Belling oven that we can't turn on. The numbers in the display are flashing and we can't figure out how to reset this or to turn it on. There are six buttons from left to right, one labelled...
We solved this by pushing both the "start cooking" and "stop cooking" buttons at the same time (these are the ones showing a pan with steam coming out of it and a pan that says stop above it). While holding these down we used the plus and minus buttons to set the time. After doing this we were able to turn the oven on.
Oct 25, 2009 | Belling XOU482 Electric Double Oven
Neff oven B1641
Turn the right hand button onto the ECS symbol. This is the cleaning cycle. Make sure you put some soapy water in the 'well' at the bottom of the oven. The oven is then steam cleaned.
Feb 27, 2009 | Neff B1641 Single circotherm super...
How do I descale a Miele steam oven?
Put the tablet into the steam generator with about 1ltr of cold water, select the cleaning cycle on your oven. let it go through the cycle.
Hope this helps
Jan 31, 2009 | Miele DG155-1 Steam Oven Single
Feb 20, 2008 | Gaggenau ED 220/221 Electric Single Oven
Ovens Logo
44 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
