Question about Samsung 26 Cu. Ft. Side-by-Side Refrigerator, RS267LA
Samsung SR-S2029CVW REFRIGERATOR NOT COOLING
COMPRESSOR NOT CUTTING IN UNLESS YOU TURN THE POWER OFF THEN BACK ON AND THEN DISPLAY RESETS TO ACTUAL TEMP
SOURCE: Samsung model SR-L38NMB refrigerator
that problem very likely is the control board. there is another brand of fridge in S.AFRICA THAT DOES THE EXACT THING OF WHICH THE BOARD HAS TO BE CHANGED.
Posted on Jul 25, 2007
SOURCE: Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Posted on Dec 15, 2007
stuarttx
  • 15 Answers
SOURCE: ONCE THE COMPRESSOR TURNS OFF DOESN'T COME UP BACK ON
The refrigerator is starting defrost mode once four hours of compressor run time has elapsed. Once the computer enters defrost mode it will remain in defrost mode until the desired evaporator temperature is reached (to melt any ice present). However, in my case, the defrost heater was not coming on due to a melted thermal fuse. (one defrost heater and one thermal fuse in each compartment). I found the thermal fuses to be open so I bypassed them. They are made to "open" at 77 degrees farhenheit. Simply storing the appliance in a garage could melt them. Hope this helps!!
Posted on Nov 17, 2008
SOURCE: samsung SR-L626EV POWER WENT OFF BUT WONT RESET. ONLY ALARM SOUNDING AND GREEN LIGHT FLASHING ON CONTROL PAD
press and hold the 2 outside buttons( the quick freeze and chill)
Posted on May 30, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Samsung RS2533SW refrigerator is not cooling.
It sounds like a defrost problem and I will help you if you need. Thanks, Sea Breeze
Posted on Jun 17, 2009
I leaned against control panel and now it reads 0 FF
Samsung Refrigerator OF OF Code On Display - How To Clear ...
https://removeandreplace.com/.../samsung-refrigerator-of-of-code-on-display-how-to-...
Oct 6, 2016 - When your Samsung refrigerator shows the OF OF or OFF code, here is how to reset it... 1 - Press the POWER FREEZE and the FREEZER buttons at same time. 2 - Hold the 2 buttons for 3 to 5 seconds. 3 - This will reset the refrigerator back to normal and the fridge will begin cooling again.
How to Turn Cooling Off Mode On/Off (RF4287) - Samsung
https://www.samsung.com/us/support/answer/ANS00048861/ To disable Cooling Off mode, touch and hold the Energy Saver and Power Freeze on the display panel simultaneously. Continue holding until you hear a distinctive chime sound and both temperatures for the freezer and fridge are displayed.
Apr 22, 2018 | Computers & Internet
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
Samsung refrige error code OF OF
OF OF means the fridge is in Demo mode and the compressor is turned off; this mode is used in the store so the unit can be displayed with actually cooling. Press FREEZER and POWER FREEZE simultaneously until the OF OF message disappears to put the unit back into normal home operation.
Oct 03, 2011 | Samsung RSG257AARS (241 cu ft) Side by...
For Samsung Refrigerator SR-L629EV my freezer
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 19, 2011 | Samsung RF265AA Bottom Freezer French Door...
Hi, SAMSUNG SR L39 stops to cool, even if everything seems ok, the fridge is on, the display lit, but food is not cold. Then turn off and turn on the fridge by the power button and everything seems to go...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 20, 2011 | Refrigerators
Refrigerator wont cool
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions: Is the refrigerator completely dead? If so, see “It's stopped completely.” Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Apr 01, 2010 | Samsung RF265AA Bottom Freezer French Door...
Samsung SR-S2028DVW american style FF keeps defrosting
I would suspect the thermostat or the defrost timer is malfunctioning.
Jul 18, 2017 | Samsung Refrigerators
Mar 15, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
99 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
