Question about Xerox WorkCentre Pro 423 Copier
Error code j6-1 reset in workcentre 423 pro - Xerox WorkCentre Pro 423 Copier
5 Suggested Answers
  • 4 Answers
SOURCE: what causes j 7 error copde in xerox workcentre
by replacing the drum unit or replacing the crum the code j7 will be cleared
Posted on Sep 01, 2009
  • 17 Answers
SOURCE: Need printer driver for Windows Vista 64 bits for Xerox WorkCentr
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=GLOBALPRINTDRIVER&ripId=&Xtype=download
You can try this driver. It may be quirky at first but it should work for basic printing needs. There is a PCL6 and post script try both sometimes it will take one but not the other. Its vista flip a coin :) -Phil
Posted on Apr 03, 2010
  • 196 Answers
SOURCE: Part list XEROX workcentre Pro 423/428
Try going to www.Xerox.com for guides and instructions. jackie
Posted on Jul 28, 2010
SOURCE: How do you change the toner cartridge on the xerox
You can always find your solution to a Xerox problem at the Xerox Knowledgebase. Here is the direct link to this solution with pictures! http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=467,E=0000000002703228701,K=8434,Sxi=4,Case=obj(862)
Solution : Replace the Drum / Toner (Dry Ink) Cartridge
CAUTION: Do not use warm water or cleaning solvents to remove Toner (Dry Ink) from your skin or clothing. This will set the Toner and make it difficult to remove. If any Toner gets on your skin or clothing, use a brush to remove the Toner, blow it off, or wash it off with cold water and mild soap. If not, launder your clothes with detergent and cold water. If the fabric label says to dry clean, inform a commercial dry cleaner that the spot is Toner so that they will not use a solvent that will set the stain.
NOTE: Make sure the Cartridge part number corresponds to the machine model. If an incorrect Cartridge is installed the message 'Check Drum / Toner (Dry Ink) Cartridge Message' will continue to appear on the machine display.
  1. While lifting the upper, right-hand cover release lever of the machine, pull the upper right hand cover towards the right until it stops.
  2. Open the Front Cover on the machine.
  3. Grasp the Cartridge by the handle on the front, and slide it toward you until the top handle is completely clear of the machine.
  4. Lift up on the top handle and slide the cartridge out of the machine.
  5. CAUTION: Do not shake the cartridge and this could cause the Toner to spill.
  6. Before you remove the new cartridge from the bag, shake it vigorously from side to side several times to loosen the contents.
  7. Holding the new cartridge by the top handle, begin sliding it into the machine as indicated in the picture above. Do not push on the handle on the front of the cartridge as the cartridge will jam.
  8. Hold the cartridge in place and pull the Toner seal tape until the cartridge is completely in place.
  9. Close the Front Cover.
  10. Close the upper right-hand cover.
  11. If necessary, press [C] on the Control Panel to clear any messages. The system will initiate a Copy Quality adjustment cycle after you press the [Start] button.
Posted on May 29, 2011
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
I have a xerox 423 with au3-5 error.whats up?
i have a xerox 423 with u2-3 error code whats that
Dec 07, 2010 | Xerox WorkCentre Pro 423 Copier
Xerox wc pro 423 u2-3 problem
my Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
Nov 16, 2010 | Xerox WorkCentre Pro 423 Copier
What causes j 7 error copde in xerox workcentre Pro 423 and how is it cleared
Aug 13, 2009 | Xerox WorkCentre Pro 423 Copier
WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Feb 07, 2009 | Xerox WorkCentre Pro 423 Copier
How to do 'mirror' on photocopier
Hi, I made a mistake, sorry. It is not a 423 Greyscale etc.. that I own but a Xerox Workcentre pro 420 black and white photocopier. I have but no manual to find out how or if it has a 'mirror' or 'inverse' function. Thanks
Dec 14, 2008 | Xerox WorkCentre Pro 423 Copier
Xerox 423, hard disk error
Hi
Replace Hard disk and try, It will work.
Dileep
Nov 05, 2008 | Xerox WorkCentre Pro 423 Copier
Xerox WorkCentre Pro 423 Copier Logo
100 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
