Question about Suunto CORE Wrist Watch
Reset stop watch
How do you reset the stop watch to zero
HOW TO RESET STOP WATCH TO ZERO
What you need to do is to pull the crown to step 2 (full out) and then push the start button. Then the second hand will start moving one tick a time all through the dial. Keep pushing it until you reach to zero.then push crown back in, That's it.
Feb 18, 2014 | Giorgio Armani Emporio Armani Sport Ar0532...
On my new Victoronox 24332, the sweep hand for the stop watch does not reset to zero but rather to about 17 seconds past '12' O'clock. The split second hand also stops just past Zero on...
Follow the instructions on the following link. I believe it works on all or most Swiss quartz chronographs. Worked like a charm for my Mondaine and my Zodiac. Hope it works for you too.
http://mondainewatch.co.uk/my-chronometer-doesnt-go-to-zero.html
May 26, 2011 | Swiss Army Base Camp 24332 Watch
My tag heuer carrera stop watch doesnt reset properly, when u reset the stopwatch it goes one minute behind and doesnt reset to zero. how do i fix this. it never resets to zero and the red hands on the sub...
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
Sep 23, 2010 | Tag Heuer Carrera Tachymetre CV2013.FC6206...
How do I zero the stop watch
Pull the winder out to either the 1st or 2nd click & use the push buttons to zero the hands in.
Jul 19, 2010 | Luminox Field 821 wristwatch
Stop watch will not reset to zero
pull the crown full out reset all hands set time set alarm or second time if you wish and press the crown back.
Dec 01, 2009 | Seiko Coutura Chronograph Watch
Howe do I reset the stop watch. It will not reset
I went to the lorus web site which has user manuals for all their watches. Went through the relivent manual whcih gave details on how to reset the stop watch facility.
Nov 06, 2009 | Seiko Lorus LO111 Watch
Guess Watch's stop watch is broken?
it's not broken.
let's call the top stopwatch button "a" and the bottom stopwatch button "b." eg, for normal stop watch function press "a" to start timing, press "a" to stop timing, and press "b" to reset.
to reset: press button "a" and "b" simultaneously and release (an easy way to do this is press and hold down "b" then press "a" and release both). this will send both hands spinning. next press "a" intermittently until the second-hand is back to it's desired reset location. then, likewise, press "b" intermittently until the minute hand is zeroed. now with both hands at the correct reset location, again press and release "a" and "b" simultaneously to save these resets and return the watch to normal function mode.
Aug 05, 2009 | Watches
Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Aug 27, 2008 | Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist...
Suunto CORE Wrist Watch Logo
22 people viewed this question
Top Suunto Watches Experts
Ansel Alberto
Ansel Alberto
Andrew Taylor
Andrew Taylor
Are you a Suunto Watch Expert? Answer questions, earn points and help others
