Question about Electric Eyeware Toys
I was four years old when my eye was got damaged with knife so I can't see with my left eye
Iwas four years old when my eye was got damaged with knife , so I can't see with my left eye
Had a pin jammed in upper knife now wont cut. Do I need to replace the knife?
more than likely as the knife blade would have been damaged and blunted
Nov 11, 2015 | Janome 6234XL Overlocker
Can low coolant in car lock up your engine
Low coolant will cause overheating- damage to your engine- depending on how low it actually is. If the coolant is less than four years old you could just add coolant (you can buy premixed at the auto parts store) to the proper level. More than four years old and your coolant should be replaced; and the system flushed in the process. If you are just adding coolant, be sure you are using the proper coolant for your car.
Apr 01, 2014 | 2005 Chevrolet Malibu Maxx
Water damage to ceiling
Cut off the loose make flat tape and drywall mud
Mar 06, 2014 | Drywall
DVD drive is not reading or writing. It is 3.5 years old.
1st option is to purchase a lens cleaner and let it run through the recommended process. 2nd option is to open it and clean the lens(eye) with a ear bud with surgical spirits, but be careful not to touch the eye to hard with the ear bud, you will damage the eye beyond repair, normally it is dust that actually split the concentrated beam that read the data in several directions. disconnect power supply when working on electrical equipment
Dec 12, 2010 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Two dvd's stuck in player thanks to a busy toddler
I had the same problem... my DVD took one in even though it already had one in there... Tweezers did not work until we used a pie server covered in masking tape with the DVD attempting to eject and then grabbed one DVD out. The DVD player works too!
Nov 11, 2008 | Rosen CV7080D Portable DVD Player
Water leaking when when washer is running a large or super load
the leak could be coming from anywhere in the washer it just leaks out from the lowest point of the washer i would suggest placing a putty knife under the top on the right and left side and pushing the tabs in to pop off the front panel to see where the leak is coming from
Oct 30, 2007 | Kenmore 24872 Top Load Washer
ITT Mariner 160 - How to open the case...
this unit is siliconed together to make it waterproof and outer ring on eye piece is glued on after assembley you have to pry casings apart with knife ect not easy but they do come apart without damaging internal parts make sure you also remove casing screw under label as well i have dissasembeled about four of this model succesfully
Wayne
Jan 16, 2007 | ITT Night Mariner 160 Monocular
Toys Logo
18 people viewed this question
Top Electric Eyeware Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Electric Eyeware Toy Expert? Answer questions, earn points and help others
