Bad driver os version 6.1.7600.2.0.256.1
My computer starts up on start up repair and then in the end the problem states the above in signature 7: as well as local id>1033
    Top Expert:
  • Computers & ... Master
  • 26,218 Answers
Hdd error I would think.
Posted on Feb 15, 2014
  • 1481 Answers
SOURCE: Windows fails to start. Startup repair is unable to repair.
insert a WinXP Cd in the CD rom drive and restart and let it boot from the disk, let it install the OS again...format the HD (u will lose all data there but ur machine will come back)
Posted on Feb 19, 2010
Sunnyrepairs
  • 808 Answers
SOURCE: Problem signature: Problem Event
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reg in out registry cleaner it will solve ur problem
Posted on Sep 07, 2010
crok41
  • 621 Answers
SOURCE: Problem Event Name: AppHangB1 Application Name: YahooMessenger.exe Application Version: 9.0.0.2152 Application
Just uninstall it through control panel then install the latest version and you shouldn't have a problem. Cheers from Scott and plz vote
Posted on Jan 13, 2011
SOURCE: Problem Event name: Startup Repair Offline
So will the computer boot or is Startup Repair hanging or looping and preventing the computer to boot successfully?
If you can't boot successfully you'll need a repair disc or operating system disc so that you can get to a command prompt (black screen with white writing) and run the check disk command.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If check disk does not solve the problem you will probably have to reinstall your operating system. Try to do a Repair Install so that it does not delete your data.
Posted on Apr 19, 2012
joelwilcox
  • 1274 Answers
SOURCE: utorrent is not responding.
have you tried to reinstall utorrent? if so, and it still doesn't work, you can remove utorrent and then run ccleaner which you can download from piriform.com after running it, try and do the installation again. if still no help i'd try a different torrent program such as vuze.
Posted on May 10, 2012
Windows 7 driver needed
If you have Windows 7 32-bit, the XP driver will probably work. http://www.driverguide.com/driver/detail.php?driverid=754345 has a copy. However most copies of Windows 7 are the x64 version. To check your OS version, click on Start and choose the Control Panel from the right hand column. Click on the System and Security link and then the System link. Read the version information. If it ends with x64, you aren't going to find a driver. You can try the compatibility mode with this driver but it often doesn't work for drivers. (Right click on the exe after downloading and choose properties. Go to the Compatibility tab and try setting it to Always Run in the compatibility mode with XP. Then right click again and choose Run As Administrator.) You may need to repeat this for the installed software as well; note the folder destination for the files.
If you have Win7 x64 and the compatibility mode fails, you would be better off upgrading to Windows 7 Pro and installing Virtual PC and XP mode. Then use the above driver in the XP virtual computer that is created. Alternatively, look into getting a new racing wheel controller that has a Windows 7 x64 driver.
This product was produced for systems with 16-bit and 32-bit versions of Windows. Since Microsoft requires digital signatures on x64 drivers, there would be significant costs to writing new drivers and getting them approved and signed. I'm not sure Game Elements is still in business.
I wish that I had better news for you.
Jan 16, 2014 | Game Elements HV-5 (GGE904) Wheel And...
I can't get Quark Xpress 9 to launch
Go to: C:\ProgramData\quark and delete all sub folders and files present there.
If that doesn't makes any difference in your case than you can run System File Checker (sfc).
You may try uninstalling Quark, rebooting the computer and re-install it.
If at all you don't get any help with that as well than you can try performing system restore.
Jan 11, 2013 | QuarkXPress 7 Full Single User Mac/Win...
Windows 7 wont start
RESET COMPUTER WITH NEW PASSWORD
Dec 24, 2012 | ASUS X52N PC Notebook
Blue screen problem
The blue screen of ***** as it is commonly known as. format yer hard disk and reinstall windows is yer only option..
Feb 04, 2018 | HP Computers & Internet
Feb 18, 2010 | Toshiba Satellite A215-S4747 Notebook
AppHang81 Error-help!
what version of windows are you using? state the version and servicepack. in the intrim, start your computer in safe mode and run some programs. shut down the computer and restart in normal mode.
Jan 02, 2010 | Compaq Presario CQ60-220US PC Laptop
Ran Reg Easy and then Laptop Toshiba Qosmio will not start again. When I use the DVD to reboot and select repair the system goes off checking and doing for some time then returns a box saying ?Windows...
when you used the Reg Easy it wipped out some of your files that are required to boot. You have no choice but to do a complete reinstall. sorry for the bad news
Oct 25, 2009 | Microsoft Windows Vista Ultimate Edition
Error msg. startup repair cannot repair this computer automatica
Hi there.
If you bought the laptop new and got no recovery disks with it, then chances are it has a recovery partition, have you go an option to press F11 during start-up and have you tried it?
May 29, 2009 | Acer Aspire 5315 Notebook
Arcsoft VideoImpression
This is windows Vista? What have you changed since it started crashing? The most common cause of crashing programs like this are the result of a graphics driver.
Mar 07, 2017 | Arcsoft VideoImpression 2 for PC
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Can I hold DHHS accountable for the burden they put upon me? If not, is there someone that can be held accountable? What can I logically and honestly do to remedy this prob. I explained my prob below! I was getting QMB part of Mainecare and my spouse at the time we were dating but living together was getting the QI part of Mainecare. We are both disabled and only get SSDI. However being honest and do our best to always do the right thing we go to DHHS office on Griffin RD in Bangor, ME within a month of us getting married where the worker we saw tells us we don't qualify for anything but the min of FS and both Q1 part of Mainecare and serious voice tells us to divorce. I have made a few trips within last months to same DHHS. One sends us to Eastern Area of Aging to see if there were secondaries we can get. This past Monday hubby and I went to our appt with Eastern Area of Aging & was told they strongly believe I could get spousal exclusion also warning it could mean my hubby loses help but because it was a volunteer a newer one at that she couldn't tell me definitely cause she didn't know the formula as she still learning; tells us to go back to DHHS to ask about spousal exclusion. So I go back to DHHS this past Thurs and got a worker with more smarts, heart with approx 10 yrs working for DHHS tells me I qualify for spousal exclusion and took the time to answer all my questions. I told her I had QMB till hubby and I married June 2016 & shared with her what the DHHS worker told us when hubby and I went in to show marriage certificate to update the change. She looked at me with shocked eyes and dropped jaw in bewilderment. Then says I would of never lost it as I would of qualified for spousal exclusion from the day we married. And had it been her that we got when we were being honest wouldn't have only told me about spousal exclusion but would of applied me as she could see I have major medical problems that is too much a financial burden for my hubby and I. She also told me I was to submit all unpaid bills even if monthly making payments were being made. I thought I was only to submit bills I paid in full or on a payment plan. So started Thurs night on a Medical Bills Tracker to go through all the medical bills and sort things out. I haven't even put a dent in the pile and see I'm responsible for just over 6K I'm predicting once done I could be closer, if not over, 10K. In collections is currently 1K but once done with pile amount in collections could be closer to 2K or more. So the mess has impacted my credit and if things were done by professionals I wouldn't be losing my hair stressing over my medical bills and how it declines my credit. I know I'm in a small group that actually pay their medical bills any and all bills to be honest! I am disabled and get SSDI. Worked 1992-2013 a lot of times working 2 jobs! Dr in 2013 practically dragged me out of work as was just diagnosed with Hep C, CKD Stage 3 & liver disease! I also have depression disorder, panic attacks, anxiety disorder! So even this incompetent DHHS worker putting extra financial burden on me unnecessarily affects those things. I am trying to do the right thing but get kicked down by the very people that are paid to help me. What are my rights and can I fix this at a faster pace then not even fixed it by the day I die?
Jun 23, 2018 | Major Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
