Restart after shutdown - Computers & Internet
  • polytek Feb 14, 2014
    Hi Theresa Louw, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    - OPERATING SYSTEM
    - ANTIVIRUS
    - MODEL OF THE LAPTOP
Commad to shutdown than restart
I don't understand the problem.do you wan't the computer shutdown for 5 minutes or hours.then restart remotly or what.you have to give more information more information please.
Mar 30, 2013 | Acer Veriton 5800 PC Desktop
Tip
How to restart or shutdown a computer through a remote desktop connection
When you are connected to another computer by remote desktop, did you ever notice that the shutdown and restart options are not there. The computer that you remote desktop to must already be on. But if you regularly use remote desktop, at some stage you will want to restart the remote computer from where you are. For example you might install a program and you need to restart the computer to finish the installation. If this doesn't happen automatically then you can follow the steps below.
How to Reboot or Shutdown a Machine from Remote Desktop Connection using Windows XP?
  1. Open the run box by pressing the WINKEY and the letter R on the keyboard.
  2. Type the following command into the run box: shutdown -r -f
  3. Press Ok.
  4. This will restart the remote computer.
If you would like to shutdown the Windows Xp remote computer you can type: shutdown -f
When you are typing these commands in you must type it exactly right. If you miss a space or a dash it will not work.
Restart a remote computer using Windows Vista or Windows Seven.
On these newer operating systems the run box is almost obsolete. You only have to open the start menu and type these commands into the search bar at the bottom. This area acts as a run box and you can type commands into this.
on Jan 29, 2010 | Computers & Internet
Tip
Create shortcut icon for shutdown and restart on desktop
For easy usage you can now create icon for shutdown and restart on desktop. Right click on desktop in that do to new and then select shortcut. Now you will get create shortcut window will appear. I this you will see one text box for select the location of the item. In that place you need to write "shutdown -s -t 00" without double quotes. and click next. Here you will find the option t rename that icon. after that click on finish.your shortcut is ready on your desktop. This icon for shutdown. If you want to create icon for restart.Follow the same steps above and in the of location of item write "shutdown -r -t 00" without double quotes..
on Dec 23, 2009 | Computers & Internet
How can i reboot my computer please
Rebooting a computer means, pressing the Reset/Restart button. But if you wish to securely restart it, click Start (Windows XP) and then "ShutDown" button, again click "Restart". There's another option when Windows XP is in Classic mode, once you press the Shutdown button, you'll see a small window showing "Shutdown", you can click the arrow button next to the "Shutdown" and then select "Restart", now click the "Ok" button to restart the system. In Windows Vista and Windows 7, click "Start", if you don't see the "Restart" button, you might be seeing the "Shutdown" button, just next to the "Shutdown" button, there's a small right arrow button, click it and select "Restart". Your system will restart.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
Hello i have problem with cmd i want to shutdown a computer that in network so pleas help me out i have typed shutdown -i and in cmd and i type his ip ... and i clicked ok and its saying erre that invalif...
You have to enter following command in command prompt.
c:\>shutdown -m \\it -s
Shutdown - This is the command u use to shutdown/restart/etc
-m - It means remote computer.
\\it - This is the computer name which you want to shutdown
-s - You have to enter this command (-s = Shutdown, -r = Restart, -l = Logoff, -a = Abort shutdown)
Hope this is working for you. If not, comment back with the problems. Thank You...!!
May 04, 2010 | Dell Inspiron 1501 Notebook
Tip
Create Shortcut for Shutdown / Hibernate / Restart
Right Click on the desktop
Goto New
click on Shortcut
Type location of the Item as "shutdown -s -t 5" Without quotes
Here Shutdown -s is the command to shutdown the computer and -t shows you the time in seconds before shutdown
Similarly you can create shortcuts for Restart by replacing the -s with -r and for hibernate simply replace it with a -h
note: you can change the delay timer as per your need
ENJOY !!!!
on Dec 03, 2009 | Computers & Internet
Tip
CARRIER WINDOW ELECTRONIC CONTROL
CONTROL PANEL ERROR CODE
PROBLEM
REMEDY
E4
Thermistor problem
Shutdown unit and restart
E3
Unrecoverable of E2RAM data
Shutdown and unit and restart
E2
Loss or corruption of stored data
Using remote control go to Cool mode and shutdown the system, and then restart.
E1
Code validation check fail
Shutdown and unit and restart.
FL
Filter check warning
Press the “MODE” and (DOWN) “▼” buttons together until error code disappear.
Note: If the problem persist replacement of control board is needed.
-Push arrow up and arrow down together for 5sec. the room temp. will show.
on Mar 02, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
My dv6000 will only restart when I select Shutdown throught start menu. How do I fix this?
Did you happen to mess with anything in control panel? well here is how to fix.
Control panel > Power options > Chose what power buttons do (on side) > and change the shutdown to shutdown and restart to restart
hope this helps
Nov 26, 2009 | HP Pavilion dv6000z Notebook
Can not shutdown /CPU fan allways working
Try the following command......
shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "comment"] [-d up:xx:yy]
No args Display this message (same as -?) -i Display GUI interface, must be the first option -l Log off (cannot be used with -m option) -s Shutdown the computer -r Shutdown and restart the computer -a Abort a system shutdown -m \\computername Remote computer to shutdown/restart/abort -t xx Set timeout for shutdown to xx seconds -c "comment" Shutdown comment (maximum of 127 characters) -f Forces running applications to close without warning -d [u] [p]:xx:yy The reason code for the shutdown
u is the user code
p is a planned shutdown code
xx is the major reason code (positive integer less than 256)
yy is the minor reason code (positive integer less than 65536)
Do reply me if it sort out your prob
Sep 30, 2009 | Abit SG-71 Motherboard
Computer restarts on shutdown
have you checked that acpi is enabled in the bios and also look in control panel, then power options and check the shutdown options are correct and not set at restart.
Apr 19, 2007 | Dell Dimension 8400 PC Desktop
Computers & Internet Logo
David Payne
David Payne
