Question about Hobart C44a Commercial Dishwasher
Gas burner won't lite to heat wash water
Temp only 123 on wash water
    Scholar:
  • 109 Answers
Asuming the gas isn't turned off.
The usual cause is a dirty or blocked air inlet to the combustion box.
Fun to get at as it's behind the conveyor drive motor. When you remove the intake baffle from between the fan and it's rectangular inlet, make a note of how many holes are covered and open. You might have 8 open and 4 half open for instance. Thoroughly clean the inlet, and fan blades and housing.
It's probably choked enough to run a rich mixture, which is reluctant to light. You may even have a backfire when the unburnt gas ignites in the exhaust plenum.
Any further in and you should be a certified gas technician.
There is an interlock switch on the burner box. If you need to go inside the box, shut off the gas. It will allow you to monitor the ignitor and hear and see the ignition arc. Process of elimination from there. Prove for good air, correct manifold pressure, ignition and flame monitor.
Remote chance its the flame rod oxidised. Have new gaskets handy if you are removing the ignitor rods, and place back exactly where they were for correct gaps of igniter and flame rods.
Posted on Mar 23, 2014
Heater fires up but won't keep heating water
Sounds like the sensor is not working shutting down too early
Jan 06, 2018 | RTO Atwood Water Heater - 6 Gal LP
Furnace won't lite have 3.5 wc to gas valve every thing seems ok was told possible cob web in burner?
If you have Natural Gas, the Water Column inch is to low. It should be about 7 water column inches. If it's a Propane unit, it should be 11 to 13 water column inches.
Hope this helped and thanks for choosing FixYa.
Sep 26, 2011 | Heating & Cooling
I ran my Jandy Lite 2 pool heater for 6 hours yesterday and the pool temp did not alter. The burners are working but the water is still cold. I have a seperate line that runs off just after the header...
Thank you for posting your question here on Fixya.com.
There are only two things that can cause a heater to run yet doesn't adequately heat the water. One is a clogged up and sooted over heat exchanger. It seems odd you do not mention periodic cycling of the heater too as usually you get heat roll-out from the bottom of the heater when this condition is present and that will trip a heat sensor from time to time.
Opening the top of the heater to expose the heat exchanger tubing will confirm this. If it is all tarred over it needs to be removed and steam cleaned and/or power washed to remove all the soot; once cleaned the heat can then be transferred thru the exchanger into the water.
The other possibility is poor gas flow either due to poor gas pressure or clogged up orifices, manifold or burner tubes. With the heater running inspect the flames from below. If they are bright blue and 2 - 4 inches tall on all the burners you heater is running fine. If not, you need to resolve the gas flow issue.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
May 29, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Burner lites but goes out after 2 or 3 min.
the white rodgers gas control needs to be replaced;
the way it works is: the thermocouple opens the pilot gas circuit and, holds it open
when it heats up by creating a magnetic field in the gas control then: when you turn
the knob on the gas control to "on" a valve inside the gas valve opens the main gas circuit and, electricity supplied by your RV keeps it open.
the main gas coil inside the gas valve is defective and, can not hold the main gas circuit to the burner open anymore.
Jul 24, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Genesis Silver B Grill: grill won't heat past 350 or so. put a new regulat...
An odd thing with many propane gas grills is how the regulator functions. If the tank is opened too fast the regulator over-adjusts and delivers no gas. Try this: Turn tank off and open all burner controls. This should clear the line of any gas. Close burner controls and open tank very slow. Now lite and temp should go up.
May 17, 2010 | Weber Genesis Silver B Grill
Burner dose not lite everytime
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 11, 2010 | Dryers
Gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Dec 16, 2007 | Heating & Cooling
Hobart C44a Commercial Dishwasher Logo
71 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
