Can not get to the belt to replace it on awa sp1 turntable
2 Suggested Answers
  • 17 Answers
SOURCE: The drive belt off my
undo clip on centre of deck circlip normally (round clip) remove deck platter round plastic that records sit on...when removed turn over replace drive belt if brokern . if just come of place belt around the inner circle so there are no twists etc on the belt ....look at near outer edge of platter there is a clip you can stretch belt to to hold so you can put over drive motor...(belt stretch from centre to clip creating v with the bely as you veiw from above ..locate motor on the deck noe alifn top of v with positin above motor .. when done drop down platter onto centre shaft again.gently turn the platter clock wise until belt locates correctly with deck ..replace clip and test ..if ok done ..if not repeat until you get it right....sometimes over time belts stretch so a new belt may be required ..ebay can supply most belts . type in turntable drive belt ..measur size of belt by cutting is it..(if strectched and no use) measure lenght of belt find replacement belt that is smaller than measurment .i.e nearest size ...hope this helps yammandan
Posted on Aug 19, 2010
Testimonial: "great help"
Hi my Awa CD player door wouldn't open the little belt is broken I need to get another one do you know where I could get one please
It can be bought from most of the electronic spare part selling shops. Keep the broken belt in hand as a sample; when you go for it.
Electro help
Dec 04, 2014 | Audio Players & Recorders
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
Awa vinyl converter to cd model 2528
http://ernie.awa.com.au/AWA---CD-Turntable/default.aspx
Jan 29, 2012 | Audio Players & Recorders
Turntable is slow, especially noticable on 33 1/3 rpm
hi,
your turn table is a belt driven one. The speed turns down when the belt become expanded. you should replace the belt of your turn table. Also put some lubricant in its center shaft ( not from the top lubricate it slightly after removing the plater).
I have here added some video related to the replacement of belt for turntables.
Not the exact for your one,for all the belt driven turntable the procedure is the same
ok
Jan 17, 2011 | Crosley CR248 Turntable
The drive belt off my AWA turntable has come off and I cannot re-configure it
Aug 19, 2010 | Audio Players & Recorders
REPLACING TURNTABLE BELT
as the belt sliped from the turntable you must replace it with new one.if upside down turntable you can see marking of belt on it.just put a new belt on turntable keep it on center.remove top rubber pad you will see three or one big hole on turntable from where you can see the belt turn that hole so you can see motor pully just hold belt by a screwdriver and pull it on motor pully.
Jun 21, 2010 | Audio Players & Recorders
Model PS-LX300USB Turntable Drive Belt
Hi Norman
Normally the belt does not go through any special tensioners or anything of that nature,The belt should go directly from the spindle motor onto the inside of the platter. Hook the belt on the motor section and lay the belt open wide inside the turntable. Next, replace the platter and manouvre the belt onto the platterinside through the two large holes
Mar 11, 2010 | Sony PS-LX300USB Turntable
Jvc turntable
hi, please check first your fuse inside your turntable, replace it if possible
Apr 04, 2009 | JVC AL A158BK Turntable
KM837 manual to fix belt on turntable
IF the belt fell off, it is likely that the belt is stretched and needs to be replaced. Use a couple of pencils to open up the belt and beasure the length. The belt should go around the two pencil erasures forming an oval. Use that measurement to determine the belt size and purchase a replacement belt. The belt will go around the platter and around the motor hub.
Dan
Feb 03, 2009 | Crosley CR248 Turntable
Stylus Needle
Do a search for Crosby turntable cd recorder.... they are the same as the AWA.... and then you can find the make of needle etc.
Sadie
Jan 11, 2009 | Audio Players & Recorders
 Grubhead
Grubhead
