Question about Samsung Galaxy Y Gt-s5360 Pink Factory Unlocked Simfree Intl Android Smartphone
Cannot open i just installed clockwork recovery mod then reboot,after rebooting it didn't open
    Master:
  • Samsung Master
  • 993 Answers
Reflash with new flashfiles by a technician
Posted on Dec 22, 2014
2 Suggested Answers
Can i upgrade to lollipop 5.0 if so how?
yes you can do it see here for the step by step detailed process.
Tutorial for Update to Android Lollipop 5.0 :
  1. Download Android 5.0 Lollipop ROM from one of the link on Bottom.
  2. Install the ROM Manager on your Wiko Barry. Get it from Google Play Store, then install the clockwork mod recovery. You also can use ROM Installer application from JRummy Apps Inc.(Get it from Google Play Store).
  3. Connect your Wiko Barry to your PC employing the USB information cable. Copy the "ROM.zip" file you downloaded to the SD memory card.
  4. Restart your device in the recovery mode using ROM Manager. As soon as in Recovery Mode, go to ROM Manager and select backup/restore to back-up your information.
  5. From the Recovery Menu do a total data erase (including Delvik Cache). When completed, go back to Recovery Principal Menu and choose Flash ROM from SD Card. Navigate the location you copied the "ROM.zip" file and follow the directions for installing Android 5.0 Lollipop on your Wiko Barry. As soon as the installation is over, just reboot your Wiko Barry device, and here you go, you've just upgraded it to the new Android 5.0 Lollipop.
For more info see: http://www.couponskingdom.in/
Sep 28, 2015 | Coolpad 9976A Octa Core 1.7GHz 7 Inch...
Android System Recovery
Obvious question is what the tablet had been doing during its' last use.
Was something newly installed, was system or apps updated, etc. ?
Were all the APPs and or system shut down properly ?
Did update or installation recommend restarting system, prior to use ? Were multiple installations / updates performed ?
Your device appears to be in a recovery boot-loop.
As stupid as this may sound ...
Is the power adapter connected ? Let battery charge for at least 30 minutes and try again.
If battery is low, it may not complete the reset. - you should have seen something on the screen, denoting " wipe and reset " procedure and completion - prior to (#1) Rebooting device
Per your post, you have already (#4) wiped the data and instructed the device to reset to factory settings, then (#1) Reboot system.
That is the generally accepted reset method
This problem is not all that uncommon, it generally results when attempting reset, internal boot commands error for what ever reason. ( can not find the factory restore / recovery file set ).
This problem is more common when "fixes ", Specialty " Roots " or "mods" have been installed by the user - making changes to the boot program and commands OR when manufacturer files have been deleted / moved from system access. - Common suggestion is to work backwards through the mod processes and / or attempt to re-install mod or follow the special mod recovery method.
Without having available the proper ROM " flash " update / installation file(s), and you may " brick " the device.
I recommend you go to manufacturer site and check for available ROM files, reset / reinstallation processes ( memory card method ? )
You state the tablet is less than six months old. You may want to contact manufacturer for possible warranty service.
They will most likely ask the referenced obvious questions, to better understand the cause / nature of the device failure and recommend the best immediate possible solution.
This may not be what you seek, I hope it will provide better direction.
Apr 20, 2014 | Hannspree SN10T1 101 Tablet
My name is Anasbabata,I have a Techno Android N3, i try to get into clockwork mod recovery but it fail to get into recovery.Normally i am entering into CWM Recovery by holding both volume + - key and home...
Try to press HOME and POWER buttons together.
It restarts the phone regardless of its state.
When restarting, keep pressing BACK button of your phone.
Oct 13, 2013 | Cell Phones
Error
If your phone is Unlocked, you probably accidentally deleted some Service apps that causes your phone to mess up.
You can try to reinstall the process.media by finding the apk.
(Android PacKage)
Or... Do what I did... I used Clockwork mod to Install a new ICS OS, into the System folder.
Then I did a System reboot and it reinstalled the entire thing like new.
Then I Rooted my phone again, and made sure NOT to delete the wrong thing(s).
(look for files u need in Filecrop.com)
Jul 29, 2013 | Alcatel Cell Phones
My dell inspiron 5620 wont go further a black error recovery screen
Shut down, unplug, remove battery, plug in, reboot, Try a system restore/recovery. If that fails, place a repair desk in the DVD/CD rom and reboot from DVD/CD rom, try a repair my computer first. Your MBR is missing or your HDD needs replacing. Is the HDD LED blinking at start of machine? Open the machine and reseat the HDD and memory mods. If that fails, remove HDD and test, replace if necessary. You didn't mention your OS? Windows XP? This may help: http://pcsupport.about.com/od/windowsxp/f/download-windows-xp.htm
Dec 17, 2012 | Dell Inspiron 1200 Notebook
How to unlock my netphone 701
smart netphone 701
problem:
smart lock
tools:
1. 1 gb mmc (sdcard)
2. z4root for ZTE BLADE
3. Recovery Manager v0.37b
4. Recovery Clockwork 4.0.1.5
5. Official Cyanogenmod 7.0.3 stable
6. Google Apps
procedure:
1. transfer all files to root of your SDCARD
2. install z4root and root your device (temporary or permanent)
3. install recovery manager
4. run recovery manager then click install recovery then select recovery clockwork 4.0.1.5 blade gen2.img
5. reboot and enter recovery mode (pressing volume down on green android)
6. backup you rom from recovery (backup and restore > backup)
7. wipe data/factory reset
8. install zip from sdcard (choose update-cm-7.0.3-Blade-signed.zip)
9. install google apps (choose gapps-gb-20110613-signed.zip)
10. reboot
Oct 03, 2012 | ASUS Eee 701 Netbook
Why install didn't sound card drivers
CONTROL PANEL SYSTEM DEVICE MANAGER OPEN SOUND,VIDEO AND GAMES OPEN IT YOU WILL SEE YOUR SOUND CARD NAME UPDATE DRIVER THEN IF IT DOESN'T UPGRADE YOU DRIVER SCAN FOR HARDWARE CHANGES. YOU COULD ALSO TRY IN YOUR CONTROL PANEL ADD HARDWARE AND SEE IF IT GIVE YOU YOU SOUND CARD,IF IT'S NOT THERE YOU CAN SHUT DOWN,OPEN THE BOX ,TAKE OUT YOUR SOUND CARD REBOOT SHUT DOWN PUT THE CARD BACK IN AND REBOOT AGAIN TO SEE IF WINDOWS FINDS AND INSTALLS THE DRIVERS?
Sep 20, 2011 | IBM NetVista PC Desktop
Help me please I am getting crazy
Get the Recovery Tool from Creative's website
Jun 05, 2008 | Creative Labs ZEN SLEEK MP3 Player
Samsung Galaxy Y Gt-s5360 Pink Factory Unlocked Simfree Intl Android Smartphone Logo
47 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
