Question about Konica Minolta Bizhub C452 Copier
Error code c-3b02 - Konica Minolta Bizhub C452 Copier
  • Konica Minolta Master
  • 6,168 Answers
The Fuser Magnetic High Current Assy. is bad not the fuser but the section it plugs into. located below the control panel behind a cover.
have a tech come out. Try this one time if the code comes back do above do above if do it again the fuser can catch on fire that will ruin a perfectly good day
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Posted on Jan 18, 2016
Model 451. What is error code 3B02?
The power supply that controls the fuser (The Hot part) unit is causing that code.
DO THIS ONCE IF IT COMES BACK REPLACE THE FUSER POWER SUPPLY OR A FIRE CAN START THAT WILL RUIN A PERFECTLY GOOD DAY!
Apr 23, 2016 | Konica Minolta bizhub Office Equipment &...
How to remove error c-3B02
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. Either of two parts bad the High Current Assemble or the Fuser GET A TECH OUT TO LOOK AT IT.
Procedure:
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Mar 16, 2016 | Konica Minolta Bizhub C452 Copier
Machine has error code c-3b02
Check the fuser unit the HOT Part. ensure properly installed. could be the fuser control board or the fuser High Current coil that part the fuser sits up against.
Jan 18, 2016 | Konica Minolta Bizhub C652 Color Copier...
Konica Minolta C552 error code C-B02
Replace the IH Power supply, it will solve your problem... Page 71 Item 5 from the parts manual.
Jul 17, 2015 | Konica Minolta Bizhub C552 Copier
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
C-3B02 in bizhub c452
This going to get expensive, could be any of the following the IH coil unit or IH Power supply unit. This series of machine uses a magnetic field to produce heat for the fusing process the process of fusing the toner to the paper, any way the code you have is stating the IH pwr sup or coil unit are not talking to the copier cpu. It could also be a relay board between the cpu fuser system, worse case the image control board. I would go with fuser power supply. Just my humble opinion.
Jan 30, 2015 | Konica Minolta Bizhub C452 Copier
C163 on b52izhub c5
3B02,3B03,3B04 - IH malfunction.Try reset the error code:
Turn OFF the copier,press and keep pressing the Function key and turn ON the copier.Keep pressed the Function key until appaire the Trouble reset message on the display.Release the Function key ,touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Dec 23, 2013 | Konica Minolta Bizhub C452 Copier
Konica Bizhub C452 Error C-3B02
chek your register conector
open the front door and clean conector
May 26, 2012 | Konica Minolta Bizhub C452 Copier
Konica Minolta Bizhub C452 Copier Logo
338 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
