Question about Advent Computers & Internet
Advent 5712 whines then goes of ,if i then cover mike or speaker apertures i can make whine come or go at will
  • Steven Schalm
    Steven Schalm Feb 15, 2014
    If you type "sound" into the search bar and click on "sound" with the speaker beside it, you are now in the sound tab. switch to the "recording" tab, then find the microphone with the green arrow beside it. Right click on that and press "properties". Click on the "Listen" tab, and uncheck the box that says "listen to this device". After you click "apply" and "OK", the whine should leave you alone.
    Top Expert:
  • Advent Master
  • 22,133 Answers
Reduce the microphone or loudspeaker volume in the mixer to avoid feedback.
Posted on Feb 14, 2014
2 Suggested Answers
  • 232 Answers
SOURCE: I need to do a
Hello !
Please check, if you have been given any restore partition on your laptop or not.
1. it may be hidden so right click on My Computer and click on Manage.
2. Then, go to Disk Management and find out is there any SYSTEM RESTORE PARTITION of like 10 / 20 GB.
If Yes, then restart the PC on Boot immediately press F8 ( ins some case F10) and follow the Onscreen instructions to restore from restore partition.
If No partition has been given, then use any Retail/ OEM disk to reinstall the OS.
It is Okay to use it as far as you have got the Legit Key.
Please make sure that Key and version on CD matches.
Posted on Jun 28, 2011
When i open cd tray pc whines
is the cd tray whining or is it a fan?
Feb 12, 2014 | Advent Computers & Internet
Every time I press my gas in my car I hear this whining Noise and I'm trying to see what it is that whining noise
does the noise sound like its coming from your speakers? if so and if it gets louder with engine rpm it is called RFI (radio frequency interference) its coming from your alternator and being picked up by your radio and coming through your antenna. hope this helps.
,Vinny
Feb 25, 2013 | Cars & Trucks
Whining noise on 2002 chevy tracker, comes and goes
Could be your alternator or a bad idler pulley. Is the transmission good? It may be the tranny or your differential whining.
Feb 18, 2013 | 2002 Chevrolet Tracker
I have a 98 ford f150 thats sounds like a power steering whine, but the reservior is full and the steering i working fine. It only whines when you get the rpm above 1500 when it shifts it goes away. ive...
Sounds similar to my Sable.. I was told that it is the power steering pump making the whine and that if I couldn't stand it, I'd have to have it changed.. Other than the whine, it works just fine.. SO, it's whined for about 10 years, now..
Sep 19, 2012 | Ford F-150 Cars & Trucks
Whining noise Computer Speakers comes and goes
This is more likely a problem with your sound card than the speakers themselves. Next time it happens, try plugging in some headphones or other speakers into the same port on the computer. Most computer hardware is not designed for good ground isolation and digital artifacts can come through.
The other likely answer is a problem with the cables. Try wiggling the cables, especially near either end, and see if you can find a spot that makes the sound come and go. If there's a break in ground at a connector, or a short to ground in the cable, that can also cause unpleasant distortion in the speakers.
May 30, 2012 | Logitech Audio Players & Recorders
Audio has a whining noise when connected through Bluetooth
I also own a Yamaha nx-b02 unit. Mine whines too, but only when connected via Bluetooth to my Vaio f series or my friend's htc.
They work perfectly on my older Toshiba laptop wich is equipped with Bluetooth 1.1. I suspect the problem only occurs with Bluetooth 2.x equipped devices. (might be wrong though)
Can anyone else add their experiences please?
Jun 02, 2009 | Yamaha NX-B02 Bluetooth Wireless Speaker
Whining noise from engine
Hello
altho new you may have a whining water pump or tensioner or it may be over tensioned.
take a long screw driver & place in on the timing cover to try to here where the noise is coming from, this should help you find the proplem with the car
Regards Paul
www.limotec.co.uk
Jan 11, 2009 | 2000 Volvo V40
Loud whining noise
yes,,this is due to electromagnetic interference...
try to keep the accessory speaker as far as possible fro the powerspeaker..this would serve better
Jul 04, 2008 | Bose MediaMate Computer Speakers
Engine whine
You're hearing whine from the alternator as it charges the battery. You could reduce it by turning the input level down on the amp, or by adjusting the filter on the high end. You can also buy a whine filter kit.
One last thing... you may have blown one of the diodes in the Alternator itself when you shorted the speaker wire. It would still work and charge the battery, but would not be able to filter the whine like it should.
Hope that helps...
Geno
Mar 25, 2008 | Eclipse XA5000 Car Audio Amplifier
RCA Whine, Newly Installed Amp
The shield ground is probably open in the head unit. You can check the shield ground by measuring the resistance from the shield of the RCA connector to the chassis of the head unit. It should be near 0 ohms. Disconnect all RCA cables from the head unit before testing.
If you find that the shield ground is indeed open, the following link has more information for a temporary fix.
Temporary Shield Ground Repair
Nov 18, 2007 | Car Audio & Video
Computers & Internet Logo
61 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
