Question about Singer Sewing Machines
Can i do interlocking using singer 1507 model
Interlock stitch
  • 323 Answers
SOURCE: hobbylock 794
You have a timing problem which needs a technician to repair. to do this properly, you need some special gauges which, generally , are not found just anywhere. Take it a technician and get an estimate before you leave it.
sewman7
Posted on Oct 28, 2008
SOURCE: Singer 8280 is not giving me a useable stitch due to tension is not properly feeding resulting , no interlocking
Make sure that the thread is not getting caught on the handle. I was having the same problem and tried everything only to find that my thread was caught.
Posted on Dec 15, 2008
SOURCE: while stitching interlock system is not working
Hi good evening. We are using USHA Flair machine when stitching the teeth is pulling the cloth can u plz help in solving this problem.
Posted on Jun 05, 2009
  • 60 Answers
SOURCE: Where can I get a Singer 1507 sewing machine manual in Russian
Okay, I looked for a while to find you a manual, but of course there isn't one in Russian. Here is what you can do though...
1. Locate your manual at the following website:
http://homeappliance.manualsonline.com/manuals/mfg/singer/ singer_product_list.html?s=gg314159
2. Use this website to translate the manual from English to Russian
http://babelfish.yahoo.com/
I Hope this helps :)
Posted on Sep 17, 2009
  • 4 Answers
SOURCE: manual for singer 1507
I scanned my manual and uploaded it to a file sharing site here is the link to the file:
www.4shared.com/file/133426020/8af58505/Singer_1507_manual.html
I only scanned in the English pages, I hope that is not a problem.
Purchased singer 6233. Filled bobbin and thought it was installed properly, but stitching just comes out by pulling on thread.
Most likely a tension problem. Tighten the upper thread tension. If the top and bobbin threads are not interlocking, then the machine is out of time. Search for sewing machine timing or take it for service.
Feb 27, 2017 | Singer Sewing Machines
Just I need help to know how to stich stretchable material like licra or similar maerial...
Asha Hello,
ok I have looked at a photo of your machine, it looks like it may have the stretch stitch. It is designated on the sewing machine per the instructions in the manual. The stitch is similar to a zigzag with a flat side to it. Check with Youtube for "stretch stitches lycra spandex". that may get you a video to watch.
Cheers,
Embroidery Services
San Diego, CA
Jul 28, 2016 | Singer Sewing Machines
Hi I'm new to sewing! Does my singer have a blanket stitch
Your machine is a beginner model with only 8 stitches. Looking at the photo of the machine, it does not appear to have a blanket stitch.
Singer 1507 Sewing Machine
Usually, only more advanced (and expensive) machines with more stitches will have the blanket stitch.
Nov 08, 2015 | Singer 1507
1507 singer wont stitch
it would be a good idea to change the needle
rethread the machine using every thread guide
make sure the bobbin is turned the correct way in the bobbin case
and that the bobbin case is correctly inserted into the machine
it's also possible that the machine could have jumped time and
needs to be checked at a sewing machine shop.
Apr 16, 2013 | Singer 1507
Loose bottom stitches on Singer 1507
top tension must be adjusted to fix loose stitches of bottom stitches
adust the top tension one letter or number higher and sew on a scrap
piece of fabric till stitches look correct,, here is a free manual
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
Jan 06, 2013 | Singer 1507
The stitches wont interlock. We have threaded it
The first thing to check is that you have the correct needle for the machine. This machine is actually the same as the Singer model 20-U machine, which is a semi industrial machine. When you broke the first needle, you could have knocked the needle bar out of time. You can test this by inserting a new needle and lower it a little (about 16th") and try to manually pick up the thread. If it does pick it up, then put some fabric in and rotate the machine slowly by hand and see if it makes the stitches. If so, then the needle bar will have to be adjusted, or you are using the wrong sized needle. If you want, you can contact me at rtarkington2@cfl.rr.com and I will walk you through it.
Jan 12, 2010 | Reliable Of Milwaukee Sewing Machines
I have a new Singer 1507 sewing machine- needle position wrong
Turn the big knob on the right of your Singer 1507 machine so that the vertical stitch line in the center. (Currently your machine most likely has the vertical stitch line to the left.) Don't push your needle manually; you will damage the needle.
Nov 22, 2009 | Singer 1507
Singer 1507 machine new. Only used twice to see how stitch looked. Tried to sew today it's been sitting for about a month. The moto runs when you press the petal but the neddle doesn't go up and down, and...
You did not disengage the bobbin spooling position on the top right of your Singer 1507 machine. Push bobbin spooling lever to the left position. Machine should be in sewing position now.
Oct 30, 2009 | Singer 1507
Oct 28, 2008 | Singer 8280 Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
