Question about KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher
My whirlpool adg 722 dishwasher just stopped in mid cycle and now it wont turn back on ,i have checked the power supply and fuse in plug top and both are ok, i carn,t locate the thermal fuse it is not behind the on button or selector switch on the front panel the machine is an intergrated model there is a circuit board at the bottom located under the door help please
    Master:
  • 366 Answers
Look for an internal fuse on the circuit board on /near pump.
Posted on Feb 14, 2014
3 Suggested Answers
SOURCE: KitchenAid kuds24se dishwasher DOA
We had same problem - took dishwasher out from counter and found it to be unplugged way way in the back 1
Posted on Sep 22, 2007
  • 6 Answers
SOURCE: I own a KUDS01FLSS3 KitchenAid
Servtek06 writes:
check connections @ control board/module. May be Control Board/Module.
Posted on Nov 02, 2010
Whirlpool ADG 7560 bleeps 4 times
Valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id, phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool Dishwashers
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
Does a Whirlpool ADG 6552 dishwasher have a thermal cut out or re-set button? If so, where is it located? The dishwasher is dead (no lights) it stopped mid cycle. There is power up to the board and the...
how do you know there's power to the board? If the board has power but no display you need a new control board. Here you go
http://www.4whirlpool.co.uk/catalogue.pl?ss=1&path=600157&model_ref=272119&refine=board
Aug 27, 2012 | Dishwashers
How do i reset the cycle programme on my ADG 954 Dishwasher
Hello
Wait for five minutes if the motor stopped itself and has been stopped for less than 10 minutes. This occurs in the event of an overload. If this is the case, the dishwasher will reset itself in approximately 5 minutes.
Turn off the dishwasher and unplug it from the power supply. Wait 10 minutes and restore power.
Select a "Hi Temp" wash cycle, followed by a heated dry setting on the dishwasher.
Repeat step 3. This will reset the dishwasher.
Aug 11, 2011 | Dishwashers
Hi. I have a problem with my dishwasher ADG 6556.
If this model has the normal wash, and heated dry buttons there is a sequence of buttons to press to do the reset, which buttons do you have, reading from left, to right on the touch panel.
Dec 29, 2010 | Whirlpool Dishwashers
My Whirlpool ADG 7550 Dishwasher trips out all my electrical sockets as soon as its plugged in. It failed whilst in mid wash. Any advice?
It is possible there is a short in the electric system in the dishwasher. There are two possibilities
1. there is a leak to the earth due to some water leakage and this causes the earth relay to trip.
2. the dishwasher motor coil or capacitor is shorted and drops the circuit breaker.
If it is related to 1, then best to take the dishwasher out from the cabinet and check with multimeter if power plug Live is showing short with Earth connection. You will have to find source of the water leak onto the power board.
If it is related to 2, then isolate the motor capacitor and try again. But 2 is unlikely if the breaker trips even if the dishwasher is not turned on.
Please post a comment if you find anything.
Sep 05, 2010 | Whirlpool 24 in. ADG7540 Built-in...
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No power to dishwasher; checked breakers they seem
you need to check the power only:
1- check the power come to the wall right ,if not
get elecricity man to bring it to plug in the wall
2- check the cord of m/c if it has fuse check it
and replace with same values ampers,....so on
3- if problem still check electricity reach at end of cord if not ,chang cord
4- if you still have problem inform us
>be ware of electricale chock it is your your life> thanks from me m abba
Jul 10, 2009 | Whirlpool Dishwashers
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool dishwasher stopped mid cycle
My whirpool dishwasher model ADP4601 is flashing a green light three times and is not doing anything else - any suggestions
Aug 10, 2008 | Dishwashers
KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher Logo
132 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
