Question about Philips Televison & Video
Philips lx3700d control
Is there a way to switch the Aux input to Aux - Ana as opposed to Aux - Digi without the remote control as I have lost the remote. Pressing SOURCE on the front panel just selects AUX-DIGI.
snakehead
  • 1074 Answers
SOURCE: No Remote, Can't Switch to AUX
you can use the channel down button scan it until it reach cnannel 3, 2. then Aux.good luck.and to get the originald remote for your tv you can buy it at www.partstore.com it wil cost you about $42.00.goodluck.
Posted on Apr 02, 2007
mixmaster
  • 626 Answers
SOURCE: Can't get into AUX source
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Posted on Sep 14, 2007
  • 375 Answers
SOURCE: Programming AUX as a channel.
pick up a universal remote
Posted on Mar 28, 2008
IrishDruid
  • 2712 Answers
SOURCE: remote control codes list for a sagem settop digi box
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
VOTIT
  • 2071 Answers
SOURCE: philips activation code for a remote control
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 22, 2008
MANUAL DE CITIZEN DIGI-ANA 8943
Hi
Full description "How to set Time" and all the functions Citizen Ana Digi Temp Cal.8943 you'll findo on http://365d24h60m.com :
CITIZEN Ana Digi Temp . Is a great complement to the ordinary manual. Many pictures, a clear description of all functions of the Citizen Ana Digi Temp : step by step ...
Regards
Apr 15, 2014 | Watches
I need to get to aux without remote on my Zenith TV
You can't select its input without its remote control.
Apr 19, 2013 | Zenith Televison & Video
Can't find a new remote for philips LX3700D surround sound/dvd system tried AVUK
Here are two websites which should help you. http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=+LX3700D+&uuid=12675636504440 This site says that your unit is a European model and the remote is not available here. They recommend contacting the manufacturer. http://www.replacementremotes.com/ This site does not list it either but they offer a $23 repair on any remote. This could be an option. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Mar 02, 2010 | Philips LX3700D System
I have Grundig - ARGANTO MW 70-510/8DPL Television. I dont have codes for Grundig TV! My remote control: One For All URC 9960 B01 (Kameleon 8 Remote Control)
The philips universal code is 0218 for the Grundig Arganto 70
However, this misses two important buttons, the codes for these are below:
134, 142 EPG
212, 220 info
some others incase your universal remote doesn't have them...
006, 012 OK
020, 028 channel down
030, 038 channel up
004, 012 mute
133 aux
230 av
165, 173, 228, 236 1
239 2
237,238 3
102 4
100 5
103 6
039, 046 8
036,044 9
007,015 off
205 contrast -
206 contrast +
215, 223 sound menu
198 colour +
061 dig/ana
063 contrast
068 vol -
069 cont -
070 vol +
071 bri +
076 vol -
077 cont -
078 vol +
079 brig +
Nov 02, 2009 | One For All Kameleon 8 (URC-9960) EL...
Philips freeview digi box dtr1500
thanks my daughter solved the problem to unlock parental lock or parental pin number she tried four zero digets 0000 no success then she put in four numbers one 1111 and it unlocked the parental lock .hope it can maybe help someone - margaret
Oct 01, 2009 | Philips Universal PH301S Remote Control
I can't switch to aux/video without my remote.
not really sure about this but if you put a disk in then run auto scan for your channels,long shot but worth a try.
May 11, 2009 | Sanyo DS19310 19" TV
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can not switch to aux mode input whitout remote control
I WANT TO KNOW THE SAME MANUALLY SWITHCHING TO AUX
Aug 06, 2008 | LG LH-D6230 System
Philips lx3700d
This HTS can't read opticals
Jan 14, 2008 | Philips LX3700D System
Televison & Video Logo
15 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
