Question about BargainCell AT&T HTC 8925 Tilt Smartphone Accessory Bundle - 2-In-1 USB Hot Sync Charging Cradle with AC Charger
Where is the SIM card located in the straight talk samsung galaxy centura
I am trying to find out where the SIM card goes in the straight talk Samsung galaxy centura
White screen on power up and wongt go away on centura
You have a bad digitizer. It is under the lcd screen.
Sep 09, 2016 | Samsung Galaxy Centura SCH-S738C...
How do I move my phone number from one Samsung phone to another? same model
Just move the sim card. If you are changing carriers then you need to contact your existing carrier and obtain a number transfer.
Oct 05, 2015 | Samsung Galaxy Centura SCH-S738C...
My Samsung 700 series went to emergency call mode and I can't get it out
remove and replace sim card failing that try sim in another phone sim could be faulty
Mar 13, 2015 | Samsung Centura - Straight Talk Wireless
How do i make my samsung galaxy centura work on roam
Go into settings from Home screen. Under wireless & Networks find More... and press, then Mobile networks. switch on Data roaming by ticking the box. May need to Data enabled tick as well up the top.
Mar 05, 2015 | Samsung Galaxy Centura SCH-S738C...
My samsung alarm clock not make noise
its may be hardware problem, pls go to samsung service center
Jul 25, 2014 | Samsung Galaxy Centura SCH-S738C...
HOW TO SET UP SAMSUNG GALAXY CENTURA SCH-S738C
If you're starting from a factory reset, or from a new phone. There should be a setup wizard that allows you to input your Google Account, Samsung Account, Twitter etc.
If you're on a second hand phone, transferring users or the like, go into your system settings, there will be a section for Accounts. The menu location changes depending on your version of Android. In 4.2.2 it's a direct tab at the top labelled accounts.
Go into Accounts. Pull all existing accounts. Remove them. Then add your accounts.
After all your accounts are synced. Your Google and Samsung profiles should pull and allow you to customize your software via their respective app stores.
Jul 10, 2014 | Samsung Galaxy Centura SCH-S738C...
Looking for manual
Refer your inquiry directly to Samsung.
Apr 18, 2014 | Samsung Galaxy Centura SCH-S738C...
Samsung galaxy centura quit unexpectedly with phone calls and internet access.
Try using another sim card in it, if that works, place your current sim in it. If it still doesnt work, ask the phone company for a new sim. You need to eliminate the possibility of a dead sim before dealing with the possibility of a defective handset.
Mar 14, 2014 | Samsung Galaxy Centura SCH-S738C...
Open Questions:
BargainCell AT&T HTC 8925 Tilt Smartphone Accessory Bundle - 2-In-1 USB Hot Sync Charging Cradle with AC Charger Logo
23 people viewed this question
Top BargainCell Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a BargainCell Cell Phone Expert? Answer questions, earn points and help others
