Why in my hp laptop sleek notebook in start menu icons flickers or their shape changes regularly
    Top Expert:
  • Computers & ... Master
  • 22,195 Answers
Check it with an external display. Just to rule out motherboard issues.
Posted on Feb 14, 2014
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: my laptop screen is flickering
You most likely have a defective inverter that supplies high voltage to CCFL backlight. It is unlikely a faulty CCFL lamp because your laptop is approx 1yr. old.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the inverter or backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 08, 2009
SOURCE: taskbar and Desktop icons flash/flicker on and off and don't allow her to open the Start menu or click any of the icons
flashing desktop icons & task bar icons please help to solve the problem
Posted on Jun 21, 2009
My facebook page is showing up in polish and i want to know how to change it back to english
Load fb. Click on the triangle shape, right most icon and select settings from the drop down menu. Select language, sixth item down.
Sep 25, 2015 | HP Computers & Internet
When I start the laptop or when the screen is
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN ... Power LED and battery charge LED start flickering when you wiggle the power .... HP Pavilion dv7-4080us 17.3-inch Desktop Replacement Laptop PC ... High-Capacity Battery For Hp Pavilion Zd8000 Series Laptops ...
www.articlesbase.com › ComputersLaptops
Jul 19, 2010 | HP Pavilion zd8000 Notebook
HP Pavilion - No. icons or start menu; only wallpaper
Try booting in safe mode (press F8 repeatedly while booting) A black screen should appera with several boot options. Choose boot in safe mode.
This should bring up a cut down version of windows.
Click on start - all programmes - accessories - system tools - system restore - choose a restore point date prior to your problems.
May 11, 2010 | HP Pavilion dv9000z Notebook
No sound and audio devices in my hp onmibook laptop
hi there..
go to your start menu,click on control panel then click on sound icon,then check that all the devices under ''playback'', ''recordings'' and sounds all show ''WORKING'' if you still have no sound after you have done this then you should change your soundcard
GOODLUCK
Feb 17, 2010 | HP OmniBook XE3 Notebook
HP 530 flickers thrice at start with vista before responding
Are you on battery or AC power,change the power setting so your laptop is running at full speed. I usually set it to Home/Office and change the video,system standby to NEVER for both battery and AC
Oct 11, 2009 | HP Compaq 6720s Notebook
Icon flickered and then the blue screen appeared with no icons how do we use w/ no icons
Do a Ctrl - Alt Del. If the taskmanger comes on you can go to File, New Task and type explorer. If no task manager then you're missing files. Reboot into Safe mode (F8 when b4 Windows starts). Then go to Start, Run and type SFC /scannow. It will probably ask for the original systems disk.
Good luck
Mar 21, 2009 | HP Compaq Presario v4000 Notebook
How to solve Flickering problem of LCD
I have an Acer 5920G that's only 3 months old and it's screen started flickering. Updating or rolling back the graphics card driver made no difference. I then updated the Chipset driver from the Acer website. It hasn't flickered since!
The graphics info has to pass through the chipset so I assume the driver wasn't up to the job.
Jan 30, 2009 | Acer Aspire 5920-6727 Notebook
Acer AL1914 flickering background
check the monitor refresh rate setting.right click on the back ground on the main windows screen. Choose proprieties from the menu that opens, then click on the settings tab on the top of property window. Next click 0on the monitor tab and increase the refresh rate at the bottom of monitor window. That should do it.
Jan 24, 2009 | Acer 19" LCD Monitor
Taskbar and Desktop icons flash/flicker on and off and don't allow her to open the Start menu or click any of the icons
restart computer and keep tappig F8 when
select safe mode from advance menu
*select win xp os
*get into safe mode and check
if u dont have any issue
then click on start->run->msconfig
click on selective startup
uncheck load startup items
click applay
click close
reboot and chack
if same problem
reboot computerr in safe mode
create new user acount
Feb 18, 2008 | Lenovo 3000 C200 Notebook
Hp laptop issue
can u explain....only icons are not showing.??? what abt the start menu and all other applications.? does it work fine..?
Dec 22, 2007 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
