Question about GPS
Unlock mapmyindia maps
I was using mapmyindaia maps in my car integrated with CASKA system. I lost my SD card recently. One of my friend is also using mapmyindia device and maps, when I inserted that card into my car CASKA system it worked. If I simply copy the content of the card to some SD card then will it work for me? I don't want to spend much on again buying new SD card from mapmyindia.
RAC_ICS
  • 143 Answers
SOURCE: tomtom 1 (new edition) map of europe
I think you'll find that you can download it from tomtom home, with full technical help online & on the phone.
I dont advise COPYING it from a friend as you will get a symbol appear on the screen with a tomtom SD card with a large red cross through it, indicating that the tomtom knows its not a genuine copy.
Posted on Dec 16, 2007
SOURCE: Lost my tomtom one SD card
torrent maps from thepiratebay.org
Posted on Mar 11, 2008
SOURCE: TomTom One map download process
baho
Posted on Dec 02, 2008
  • 24 Answers
SOURCE: Tomtom one cant unlock maps
well,then there is only one way, that definetly works, ttsystem patcher, if tomtom company doesn;t want to help, we can do it our self ;)
there are lots of warez about ir ;) in www.twingine.com ;)
Posted on Mar 01, 2009
jiggawatt__n
SOURCE: Update wiped out all maps on my Magellan Maestro 3140
need to install drivers first. computer will reconize it as a mass storage device. look for it in the my computer center, usually called TFat. You will need to install all the files in manually.
Posted on Jun 11, 2009
I recently purchased a used car with parrot v5.11c system installed. But the GPS NAVIGATION SD CARD is missing. How can I get its navigation software?
usually software is inside the chip. On SD there're maps: you'd have to subscribe/buy a map subscription.
Apr 26, 2015 | Parrot GPS
You won't know until you try it. If they have the same maps, that may work. If you do not want to pay extra, do not lose your card.
Feb 14, 2014 | GPS
C-map sd card invisibile
Ok apparently the problem is due to the way you copied the program as the SD card and if the gps that you used is the same .
if you use the same gps sd card then you must find in the internet some program that will help you copy the files in the new card that the gps can run in the right way . you use the same gps sd card then you must find in the internet some program that will help you copy the alchivos in the new card in a way that the gps can run in the right way .
Jan 13, 2014 | Simrad NX45 Navstation
I have got mapmyindia version 5 from my friend who has a mapmyindia GPS device. How do I load these onto my Garmin Nuvi 205 which already has mapmyindia version 4 (india 4.01) maps loaded.
whats the format? is it in .img format? or is it windows ce application. if its later it cant be loaded to ur nuvi.. if its .img format it ha sto be unlocked to be loaded into nuvi
Dec 17, 2010 | Garmin nuvi 205W GPS Receiver
Maps are locked on sd card how do I unlock them to use them?
Normally there shouldn't be a problem taking maps off of an SD card. The only time that a Garmin unit will put lock codes on maps located on an SD card is if the maps were purchased and already unlocked on another unit. If someone tries to then use those maps on a different unit the Garmin system will check to see if they have been accessed already. If they have then the unit locks them out. The only other thing that may be going on is that someone else put a password on the maps. If that is the case then you will have to get that person to give you the code.
Mar 16, 2010 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
Move Maps rom SD Card to Unit
Hey,
here is the owners manual
http://www.garmin.com/manuals/nuvi200_OwnersManual.pdf
on page 3 you have instructions on how to unlock optional maps.
2b4ea47.jpg Let me know if you need anything else.
Thanks,
Ekse
Feb 25, 2009 | Garmin nuvi 200W GPS Receiver
New Maps - Can't update unit
The new maps will be unlocked to your GPS using the code Garmin supplied you.
You will have to add these maps to a second SD card if your present card is full, or else purchase a larger card. Since all the Mapsource NT 2008 Europe maps are 1,395MB in size, you'll need to purchase at least a 2GB SD card.
Mar 27, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Download india map in tomtom gps
There are no India maps for tomtom. For India maps you may use Mapking, SatNav or MapMyIndia (best maps but with lousy software).
Feb 06, 2008 | Tomtom One Europe v2 GPS Receiver
USA MAPS
You need to buy a preloaded SD card, purchase maps from Garmin and download them to a blank SD card.
Dec 10, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
46 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
