Question about Apple iMac Computers & Internet
Start up programs - iMac Apple Computers & Internet
    Top Expert:
  • Apple Master
  • 14,161 Answers
Posted on Feb 24, 2016
I have a 12 station Orbit Model #57900and I want to water the same stations two to three times a day
Program modes
Program A or 1 is your primary program setting. All Zones will run on this program.
Select program B. Or 2
Set start time for program B usually an hour or two after the LAST zone (12) run time on program A or 1
1. set selected run time for the zones you want to run. 5 min -20 min ( leave the others 00:00 or off)
Select program C or 3
And repeat above.
Keep track of the start times of each program as 12 zones running for 10 min will add up to 120 min or 2 hours total. So if Program A/1 starts at 6am it will finish at 8 am. Set program B/2 start time at 11am. Them select the specific area/zone you want to run again will water the area a second time. Just remember to leave the other areas you don't want to water Set at 00:00 or off. Repeat through all the programs and you off to enjoy your day. Cheers
Jun 06, 2016 | Orbit Hardware & Accessories
Please help! It turns on, command light is flashing green, no turn off, doesnt move if i dont put water in manually
Failures, which occurred during the program will store and indicate for customer by flashing start LED (light-emitting diode). Appliances which have no program sequence or no 7-segment display can't exatcly show the failure. On these appliances the failure can only be found by starting the test program.
The passive test program shows the stored failure. If there is no failure the passive test program runs normal.
1. Switch off the appliance
2. Push start button and hold it
3. Choose position 1 of the "turning knob" turning right side (program 1).
4. Finish pushing the start button when the start LED flashes.
5. Failure indication
6. Repair the failure
7. Solve the failure by pushing the start button for longer than 3 sec.
8. Start the passive test program again. If there is no failure detected, test all LED's and after that choose program 1.
9. Finish the passive test program by pushing the start button for shorter than 3 sec.
Thank's to your description of failure I will check all hydroulic inlet water circuit and electrical component in "inlet water" phase (electrical valve, flow meter (if exist), OWI, VWI, wiring, CB...etc)
Dado
May 30, 2015 | Whirlpool Dishwashers
How to find lost programs on a computer?
click start all programs you should see all programs you have or click start all programs accessories also
click start search type in part or all of the name of the program then press enter to search
hope this helps you
Aug 24, 2011 | Computers & Internet
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Aug 16, 2011 | Nokia N70 Cellular Phone
How can i run add remove program without going to control pannel?
Do START, RUN then type in C:\WINDOWS\system32\appwiz.cpl
Most programs also have a separate uninstall program in their program group - Do START, ALL PROGRAMS, select the program group you want to uninstall and see if there is an uninstall icon.
May 17, 2011 | Microsoft Windows XP Professional
How do I add programs to the Start Menu?
Drag the program icon on the start button, the start menu will open. Drop it there.
Mar 15, 2011 | Dell Computers & Internet
Roxio Media Manager program installation will not complete. How do I uninstall.
Posted all operatings systems...
In Windows, how do I uninstall programs? Using the Add/Remove Programs control panel The Add/Remove Programs control panel in Windows makes it easier to uninstall programs. Follow the appropriate instructions below to use this control panel.
Windows 7
  1. From the Start menu, select Control Panel.
  2. In Large or Small icon view, click Programs and Features. If you're using Category view, under "Programs", click Uninstall a program.
  3. Select the program you want to remove, and click Uninstall. Alternatively, right-click the program and select Uninstall.
Windows Vista
  2. In Classic View, double-click Programs and Features. If using the Control Panel Home view, under "Programs", click Uninstall a program.
Windows XP in the default XP view
  1. From the Start Menu, select Control Panel.
  2. Click the Add or Remove Programs icon.
  3. Select the program you wish to remove and click Remove.
Windows XP in Classic View and 2000
  1. From the Start menu, select Settings, and then Control Panel.
  2. Double-click the Add/Remove Programs icon.
  3. Select the program you wish to remove and click Add/Remove.
Using the Uninstall program from the Start menu If the program you wish to uninstall is not listed among the installed programs, an uninstall program for that item might be available on the Start menu. To look for such an option:
  1. From the Start menu, select Programs or All Programs.
  2. Find the folder for the program you wish to uninstall and highlight it.
  3. In many cases, on the menu that appears, you will see an uninstall option.
Please let me know how this works out for you...
Thank you
Jon
Aug 12, 2009 | Computers & Internet
No new icon even after the program shows successful completion
OK, if the program can be found in the start menu, (Start/all programs/ "the program")
Then right click on it and select " Send to> " move across the next select box which appears and select " Desktop (create shortcut)
If your program isn't in the start menu, then go Start / Control Panel / Add or remove programs (XP) OR Programs & Features (Blista) check if the program you installed is listed, if it isn't reinstall it, if it is, Right Click on Start and select "Explore" Find the Folder in the tree called Program Files, in that folder find the Folder with your program name, in that folder drill down to you find the program name .exe (it will be type Application) double click and find the one that opens the required program eg. CinePlayer is here, Local Disk (C)/Program Files/ Roxio/Digital Media Plus/CinePlayer/CinePlayer.exe
Right Click and select Desktop (create shortcut) and/or Pin to Start menu
Sep 28, 2008 | Computers & Internet
Missing
You would right click on Start go to Explore, look under under id in "Start Menu\Programs", you would cut/paste or copy paste the programs to AllUsers\Start Menu\Programs.
Jul 26, 2008 | Computers & Internet
Toshiba mk 4004gah
When Windows starts up, a number of programs will start automatically. Most of them don't need to start but they do. The more programs that start up, the longer your computer will take to load everything.
The first thing to do is to get rid of all the junk in your computer. Uninstall any program you no longer want.
Clearout all your old temporary internet files.
Do a registry and adware clean.
Get rid of old documents and files, anything you do not need.
To see the programs that start when you boot up:
Click Start
Click Run
Type msconfig
Click OK
When the window opens Click Startup
You will see a vast number of programs that your computer loads each time you boot. You can uncheck a lot of them. Do a google search for startup programs before you uncheck anything. There are some good guides that will tell you what to allow to start and what you don't need. Note any unchecked program will not be deleted or uninstalled and will still work when you want them. You will need to restart your computer if you make any changes in msconfig
I would also suggest you defrag your hard drive.
Go to Start-Programs-Accessories-Syatem Tools-Defragmenter
Follow the instructions.
Do not rule out the possibility that you have a virus or some other spyware program running in the background which slows things down. Check these out too.
Feb 10, 2008 | Toshiba (MK4004GAH) 40 GB Hard Drive
Computers & Internet Logo
308 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
