Question about Gaggia Unica Bean To Cup Coffee Machine
Machine turns on, warms up but will not dispense coffee
This happens intermittently. The brew group is clean, greased and I have descaled the machine it just seems as if something is not working in the brew group. If I just take the brew group in and out, work the mechanism by hand several times then eventually it rights itself but I have no idea what I've done to fix it. Any ideas?
  • 3 Answers
SOURCE: Gaggia Titanium integrated grinder not spinning, not grinding.
your grinding chamber is blocked, the same happened to me, did it struggle to grind before? try taking the black shoot out the top with the 2 screws( were you would put pre ground coffee in) take the brew unit out(along with the waste water and bean tray), and reach up to where there is a little spring, the spring controls a little door, if you open the door manually and clean out the shoot to the grinder( make sure the machine is unplugged for this), i used the end of a tea spoon and a little hoover. it should work after this
Posted on May 16, 2009
espressonist
  • 1711 Answers
SOURCE: I cannot get the brew group out to clean in my
Check the position of the gear if the small arrow is not matching with the N this mean that you have a mechanical gear problem and need to desasembe the machine in order to find the broken part. If the arrow mutch with N the the problem is due to coffee that dry out and the group is only stuck in, by a little force and a slight movements left and right you can easily unstuck and you can clean it with running hot water under tap. The problem it can also by a brocken lock lever so when you press the level by your hand this is broken and can not unlock the group so you can remove it out. You can try to use a long screwdriver to unlock it so it can then remove it.
Good Luck
Please remeber to vote for this answer
Posted on Feb 27, 2010
EsWorld
  • 1618 Answers
SOURCE: I have a GAGGIA SYNCRONY DIGITAL COFFEE MACHINE,
The grind is set too fine adjust to a coarser grind.
Posted on Mar 02, 2010
EsWorld
  • 1618 Answers
SOURCE: Gaggia Evolution is overheating
Check the thermostat on the side of the boiler, that might be damaged.
Posted on Apr 12, 2010
tunde007
  • 2382 Answers
SOURCE: water circuit wont prime. clicks
Hi, if you have done all these necessary procedure and the unit will still not prime then you have to see on of their service agent around for it to be serviced.....
Posted on Feb 20, 2011
I cleaned my Jura Capresso with a tablet, but the message "Clean Machine/Ready" won't switch back to "Ready". Any suggestions?
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 06, 2016 | Jura Capresso Impressa Coffee Makers &...
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
While performing the descaling the brew group gets stuck
Have you check if the knob on the top of the machine to distribute hot water is fully closed. If on the edge, you may not get hot water flowing but the light may be on.
Look on page 12 of the manual. It explain the the meaning of the led flashing or stayed on from the control panel
Good luck
Aug 30, 2014 | Saeco Odea Giro Plus Coffee Maker
I have a Saeco Incanto Classic. There is hardly any water coming through the coffee dispenser even if I only use the preground doser without inserting coffee. While the little water comes out it makes a...
Sounds like the the shower screen under the red o-ring in the brew group needs to be cleaned, you can remove the screen and clean or you can purchase some espresso machine soap puro caff or puly caff, and run it through the brew group using the preground method the clean out coffee oils.
Aug 26, 2011 | Saeco Incanto Classic Espresso Machine
My descaling and coffee grounds drawer light were blinking alternatively. I did as the instructions said and turned the machine off then back on to no avail. So I removed the grounds drawer and brew...
Make sure the brew group is in
rest position; the two references
must match.(look at the marks/arrows on the side of the brew group)
Make sure the components are in
the correct position.
The hook shown must be in the
correct position; to check its
position, firmly press the "PUSH"
button.
Jan 14, 2011 | Saeco Odea Giro Plus Coffee Maker
Where to apply grease to brew group
i no what you mean if you grease the slot you gonna have more maintenance to more often coffee dust goes in that grease have to clean with hot water more often but its what you have to 95% of time when those machine break down its bad maintenance had mine for over 14000 shot the only thing i had to do beside maintenance is completly dismantle the brew group for a good clean up that it clean or machine once a mounth descaling it every 3 mounth you gonna have it for a long long time p.s the grease make it easyer for the gear inside thanks
pierre
Aug 02, 2009 | Saeco Odea Go
Steam comes from wand when set to dispense water.
Check the connection to the boiler from the pump, there is no water going to the boiler. Try this test, remove the brew unit you will see a white plastic valve behind it, carefully lift the small lever on the valve(HOT WATER), if water sprays, then the problen is at the brew unit, if no water then the boiler inlet or outlet is clogged.
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Incanto -- no coffee coming out
After I posted this I decided to descale the machine again, even though I'd just done it a couple of weeks ago. After descaling and rinsing I tried running water through the brew group by pressing the pre-ground button, then holding down the big cup button. Still no water, but then I turned the little knob on the coffee dispenser counterclockwise, about half a turn. It worked! I rinsed it well, then made a cup of delicious espresso.
Mar 01, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Royal Digital won't brew coffee
normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
Jan 11, 2008 | Saeco Royal Professional Espresso Machine
Gaggia Unica Bean To Cup Coffee Machine Logo
42 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
