Question about ASUS WL-500W Router (WL500W)
I need to get port number from D-link so that I can add it to my hhu for connection so that I can transfer data
    New Friend:
My D-link wireless router dsl-2750u showing red in power
Posted on Feb 14, 2014
Why does my nexxtech usb 2 0 data link cable not connect between a WD MyCloud and a MacBook Air
This cable you have is only for transferring data from one computer to another. To transfer data to this drive you must do so over the network or by loading your content onto a USB drive then connecting the USB drive up to the USB port on the WD MyCloud and using the MyCloud app to copy the data from the USB drive to the internal storage of the MyCloud drive. See the link below for more information. WD My Cloud Direct USB Transfer and SSH Access
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Sep 07, 2014 | Apple MacBook Air
HU8643773
Here is what I have for that model of PS2.
The 128-Bit Emotion Engine is the first chip of its kind. No other mass-market computer technology on the market comes close to its power. In the PlayStation2, this chip is used as the workhorse of the console. It processes all physics and math calculations.
The PlayStation2 has a 128-Bit Emotion Engine. The 128-Bit part of the title means that this chipset both processes information and sends it over a 128-Bit bus (A Bus is the pathway between chips on a circuit board. A wide bus carries more bits of information and is thus faster than a narrower bus).
You may think that your PC has a faster processor, but remember that the Emotion Engine has inherently faster 128-Bit processing and it is just a part of the overall PlayStation2 power.
A small note for the really detail oriented: The reason that the speed is 294.912 MHz, is that it must be a multiple of a required processor speed that supports the DVD ROM operations.
* Dimensions: 301mm (W) x 178mm (H) x 78mm (D), (12" x 7" x 3").
* Weight: 2.1 kg (4 lbs. 10 oz.).
* Media: PlayStation2 CD-ROM, DVD-ROM, and PlayStation CD-ROM, CD Audio
This means your PlayStation 2 will basically play all your old PlayStation games (but not make them look any better), all music CDs and all North American DVDs.
* Interfaces: Controller Port (2)
These are the same as the controller ports on the current PlayStation.
* Interfaces: Memory Card Slot (2)
These slots are very similar to the ones on the original PlayStation, except they support the new, faster transfer rate.
* Interfaces: AV Multi Cable Output (1)
This is where you plug the cord that goes to the back of your television.
* Interfaces: Optical Digital Output (1)
This port will let you send data directly to a digital receiver. This is perfect if you plan to plug your PlayStation into a DTS or Dolby receiver and get perfect sound.
If you don't use digital output, your data will be converted to an analog signal and then be converted back to digital at the receiver.
* Interfaces: USB Port (2)
USB enables you to connect any number of devices to your system with a high-speed data link.
* Interfaces: I.Link (IEEE1394) (1)
The IEEE139 port is known by two names: I.Link and for Mac owners, FireWire - there are some minor differences between the two. This high-data transfer port has the advantage of supplying (some) power to devices that are connected. You can expect that an enormous number of hardware devices will use this port including speakers, printers, and other like devices.
* Interfaces: Type III PCMCIA Card Slot.
This slot is a lot like a laptop's add-in slot. Here you will be able to plug in a modem and eventually the connection for Sony's planned broadband network and hard drive.
Jul 28, 2014 | Sony PlayStation 2 (PS2) Console
What does 192,168,1,254 mean?
Your server may be In Active mode, the FTP client chooses the port number that it will use to transfer data on and tells the server which client-side port to send the data to. It issues the PORT command to let the server know what IP address and Port number it will be listening on to receive the data from the server.
PORT 192,168,1,254,4,15 The server then initiates the data transfer to the client, sending the data to the port number that it was told to by the client. Since the Server has initiated the connection, a stateful firewall will not allow the data to be sent back though. (No client has created the connection and so no respective connection exists.)
Hope this helps.
Good Luck
C2Solutions
Feb 16, 2012 | Dell Computers & Internet
What cable or adaptor do I need to transfer all data from the hard drive of my Toshiba Satellite Pro A200 via USB port? Thanks.
you do not need any special adapter or converter just use portable hard disk to take back up of data
seagate, transcend
Mar 14, 2011 | Toshiba Satellite Pro A200-EZ2204X...
How to connect my d-link 2 my pc's (laptop and desktop) for data transfer
power on switch , have two patch cord with you, first connect in pc's eathernet port and second in laptops eathernet port,connect those cables to switch's lan port respectively start the switch and turn on pc and laptop and main thing enable sharing in remote desktop.
Mar 02, 2011 | D-Link DES-1008D 8-Port Ethernet Switch...
I have a switch Dlink (DES-3026). All the status LEDs are blinking together with orange color. Is there any problem in that?
Blinking LEDs show data activity (Send & Receive) at the connected ports. So, there is no problem as long as the switch is performing well
Good Luck!
CreativeTECH
Feb 01, 2011 | D-Link Computers & Internet
I have a samsung VP-D70 camcorder and I want to transfer data to my laptop. The DV out on the camcorder is descibed as 4 pin the other end of the cable supplied is not usb (it has 723 on the connector).I...
This is a Firewire cable, also known as DV or IEEE 1394. Sony call it i.Link. It is not compatible with USB and you cannot get a lead to connect it to a USB port. There are converter/adapters that are supposed to allow Firewire to connect to USB but many forum posts say they do NOT work for video transfer. Unfortunately, most Mini-DV cameras will not transfer video by USB cable, even when they have a USB connection (it is usually only used for still pictures).
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. If you had a desktop PC, you could fit an add-on Firewire interface card to the expansion bus. This will come with a driver for the card.
I have a Samsung Mini-DV, and do transfers with it to the one computer I have that has a Firewire port. It is the only thing I use that computer for, and the reason I haven't thrown it out.
Jan 16, 2011 | Samsung VP-D70 Mini DV Digital Camcorder
Have mini dv recorder, need dv to usb cord to load videos on pc
There is no such cord. You will need to have a DV port on your computer and use a DV cable to transfer the data. If you don't already have a DV port, then you can get add-in PCI or PCcard firewire cards that will give you a DV/firewire/IEEE1394/i.Link/s400 port (all those are the different names that manufacturers call the port).
Nov 30, 2010 | JVC Video Cameras
I have got transcend storejet 25M 320Gb external hard disk.....when i started using it i transferred some data from my PC to the hard disk and the transfer speed which it was showing was 1.2mbps which is...
You connected it to a "USB 1.1" socket in your computer, which is only 1/40 of the speed of a "USB 2.0" socket (if your computer has any such USB sockets). If you don't have any USB 2.0 ports, buy a PCI add-in card to add some ports to your computer.
Nov 01, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to ti-cares@ti.com.
Oct 22, 2009 | Texas Instruments TI-83 Plus Calculator
Open Questions:
ASUS WL-500W Router (WL500W) Logo
55 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
