Question about Belling 3 cu. ft. / 85 liter Upright Freezer BE809
Need manual for freezer type zop11066 model be809
Specs of tev for mccall freezer
you need model number and serial number . refrigerant type and possibly the compressor model number to determine the txv type and capacity
Nov 26, 2012 | McCall Refrigeration Commercial Freezer...
Temperature control are the lower numbers colderr or warmer?
Hi there, the higher the number the colder the fridge, unless the numbers are in degrees. If it's numbered 1-6, 6 is the coldest. -Alex
Aug 17, 2011 | Belling 3 cu. ft. / 85 liter Upright...
Ocean Frost Free dial keeps going inro Red/Black & we have no Manual
Hi clarry441,
I would like to clarify if what is the brand, type and model name of your unit?
Thank you for using FixYa.
Jun 27, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How do I get to the thermostat on a belling be809?
u can get parts online just put be809 thermostat and your area were u r too. it should bring a list of shops ect to buy it from ...try ebay too. or if you are in uk i can order it and send to u. bsc appliances 07779933829
Feb 27, 2011 | Belling 3 cu. ft. / 85 liter Upright...
What type of light bulb does the freezer use
May I get the model # so I can help you get the right bulb
Aug 22, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
Belling freezer wont freeze, red light remains on all time. Turned on and off, adjusted temperature setting, cleaned but nothing makes any difference. Can hear pump working but does not cool.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 06, 2010 | Belling 3 cu. ft. / 85 liter Upright...
Will not freeze. all lights are on at the frount and the red alarm is going off
red alarm is for temp. to high.
i am going to tell you the possible whys, not how-to fixes because that will take too long.
Compressor not running
short of freon
if have (freezer fan not running)
if have (condenser fan not running)
thermostat not working
defrost (if have) not working
timer (if have) not working
wasnt sure so i wrote if have... could not find a diagram of all the parts listed for this freezer
hope it helps alittle
Mar 27, 2010 | Belling 3 cu. ft. / 85 liter Upright...
How can you tell by looking if a freezer is a manual defrost or self-defrosting type? Thanks
If you have freon lines running through your shelving, this is a manual defrost. If you have an evaporator fan motor blowing air in your freezer compartment this is a self defrosting model. Good Luck, Appliance Specialists
Jan 13, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
I LOST POWER TO MY KENMORE FREEZER AND NOW MY ALARM IS GOING OFF.
I would leave the door closed unplug it for half an hour. In that half hour go to sears.com customer service, manuals and guides and type in the full model number from the freezer. You should find an owners manual there to print or just browse for an answer. Good Luck.
Jan 09, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
No owners manual
I solved the problem by avoiding this stupid website that only screws you around trying to sell you something and go somewhere else. If your stupid response program would have noticed i asked a question about a different freezer you ****.
Dec 21, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Belling 3 cu. ft. / 85 liter Upright Freezer BE809 Logo
175 people viewed this question
Top Belling Freezers Experts
AJMAL KHAN
James Coghill
Tom Chichester
Are you a Belling Freezer Expert? Answer questions, earn points and help others
