Device Device name: E153 Application port: COM6 Serial number: M5D4CA1190616220 IMEI: 868672000272549 Hardware Version: CD1E153M Firmware Version: 11.609.20.11.356 Software Version: 16.001.05.00.45 SIM/USIM Own number(MSISDN): Unknown Messages in SIM/USIM: Unknown Contacts in SIM/USIM: Unknown Message center number: PIN code status: Ready Network status Network name: Unknown RSSI: -71dBm CS network registration: Registering PS network registration: Registering A Network settings APN: vinternet.in Network selection mode: Automatic natwork signal 0%
4 Suggested Answers
SOURCE: RCA DCW615R WIRELESS Cable Gateway , Factroy Installed Firmware needed.
I had the same issue with my RCA DCW615R. First time my ISP Comcast flashed it back to the old version. This time I could not find anyone who new how to do that. I used to have the software and I have searched the net. Seems they provider RCA does not have it.
This time I called Comcast because I noticed that the 192.168.0.1 brought me to their software update. They supplied me with the user name and password. I was able to get into the firmware and change all the settings using the new firmware. I think the only reason they gave it to me is because my printer is a network printer and it would not work unless I could access the firmware.
The old 192.168.100.1 does not work anymore because that was Cable Modem mode or CM mode. The new address 192.168.0.1 does work but you will need the user name and password from your ISP, this is RG mode or residential gateway mode.
Liked the old firmware better but they both do the same thing. Seems the Gateway works better with the new update. Still I would like to find the old firmware not sure why RCA doesn’t have it.
Posted on Jan 07, 2008
WeListen2You
  • 538 Answers
SOURCE: USB UNKNOWN DEVICES
methinks you are getting vistalized at the bios level..check on that by doing a windows update..
Posted on Oct 23, 2008
SOURCE: PLEASE PROVIDE 10 DIGIT NCK CODE TO UNLOCK OTHER
please provide 10 digit nck code to unlock other sim excpt bsnl modem name micromax mmx310 3g usb manager at part:com19 Firmwave version:LQA0094.1.1_MG32 IMEI:910532501346259 IMSI:404437007666173
Posted on Apr 28, 2011
Modem name: MMX310G 3G USB Manager At port: COM 23
IMEI: 910532501150347
Please provide the nck code for MMX310G 3G USB Manager
Thanks
sthita_50@yahoo.co.in
Sep 28, 2013 | Computers & Internet
PLEASE PROVIDE 10 DIGIT NCK CODE TO UNLOCK OTHER SIM EXCPT BSNL Modem name: MMX310G 3G USB Manager At port: COM 4 Firmware version: LQA0094.1.1_MG32 IMEI: 910532500939898 IMSI: 404811170299493
Feb 02, 2011 | New Media NetSurfer 56K USB (NMT00700)...
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Unlock code for Micromax MMX 310G IMEI NO:. 910532500953618
Modem Information
At port: COM 7
IMEI: 910532501000674
IMSI: 404742151782835
PLEASE PROVIDE NCK CODE TO UNLOCK OTHER SIM EXCPT BSNL
Dec 09, 2010 | Computers & Internet
I had a problem with updating firmaware for OpenComms
Liebert says there is a known issue when you try to upgrade from 2.200 to 2.400, you are supposed to upgrade to 2.300 first or it will lock up when you connect to the network. You have to call Liebert and ask them to send you the 2.300 firmware. Downgrade the firmware to 2.300. Once you have 2.300 on there you can upgrade the card to 2.400 via the web interface and you won't have to mess with the Xmodem upgrade process again. Make sure you follow their instructions for downgrading, there is an extra .bin file that you have to upload to the card first.
Nov 07, 2009 | Liebert OpenComms Web Card (OCWEBCARD)...
Where do i find the device code on a HTC Touch Diamond?
By device code if you mean serial number, pop open the back cover (push it up, when the USB port is facing down, I did it the wrong way the first time, yeah its embarrassing haha). Then take out the battery, the serial number should be located there.
If you mean something else, like rom version, hardware version, etc or Model number, those can be found in start>settings>system>device information.
Dec 01, 2008 | HTC Touch Diamond Smartphone
Can;t use intent on mobile
Here is what you should do step by step:
I.Configure your Computer
1.Install Bluetooth Adapter
2. Bluetooth Configuration->Local Services-> Add Serial Services ->Bluetooth Serial Port->Properties
Check – Startup Automatically
Check – Secure Connection
COM Port: COMx( mine is COM6)
3.Control Panel -> Phone and Modem Options->Modems->Add-> Check Don’t detect my modem->Next->(Standard Modem Types)->Communication cable between two computers->Next-> on witch port do you want to install it ? -> Selected ports -> COMx ( in my case COM6)->Next->Finished
Now in phone and modem options->Modems you should have : Communications cable between two computers : Attached to : COMx ( COM6 my case)
Select Communications cable between two computers -> Properties->Modem-> Maximum Port Speed : 115200 -> ok ->ok.
4.Control Panel ->Network Connections ->Create a new connection-> Next->Set up an advanced Connection-> Next-> Accept incoming connections->Next-> Check : Communications cable between two computers ->Next-> Check: Do not allow virtual private connections->next->next->select: Internet Protocol(TCP/IP)->Properties:
Network access : Check Allow callers to access my local area network
TCP/IP address assignment : Specify TCP/IP addresses:
To: 192.168.0.y (y=52 in my case)
->OK->Next->Finish
5.Network Connections
Bluetooth Network -> Enable
Internet Connection ( your internet connection ) -> properties->Advanced->Check:Allow other network users to connect trought this computer’s Internet Connection->OK
If all goes well : Bluetooth Network-> Properties-> Internet Protocol ( TCP/IP)->Properties Should have the following setting:
Checked Use the followind IP address:
IP address: 192.168.0.1
Subnet mask: 255.255.255.0
->OK.
6.Start->Control Panel->Administrative Tools->Services->Routing and remote access->Properties->General: Startup type : Automatic - this service MUST be started
**7.Install AnalogX Proxy http://www.analogx.com:80/files/proxyi.exe (for the latest version)
Proxy->Configure-> Proxy Binding: 192.168.0.x ( for me x=50 )->ok.
! If you use a proxy, remember to start it .
II. Configure Phone:
1.Install GnuBox - http://gnubox.dnsalias.org/gnubox/ ( for the latest version)
2.Configure Access point
Tool->Settings->Connection->Accces Points-> New Access point->Use Default Settings
Connection name: Bt
Data Bearer: Packet data
Access point name : Bt
User name: none
Promt Password: NO
Password: ****
Authentication: Secure
Homepage: none
Option->Advanced settings
Network Type: IPv4
Phone IP address: Automatic
Name Servers: Automatic
**Proxy serv. Address: 192.168.0.x ( for me x=50)
**Proxy port number: 6588
3.Configure all the applications from your phone witch require internet acces to use Bt Access Point
4.Configure GnuBox
Options->Install Set to GPRS
Options->Install Create Records
Options->Install->Copy settings from GPRS
Options->Install->set RAS login script
Exit GnuBox
Open Gnubox
Options->2box Bluetooth->Serial Port
Select – your computer
Do you want to require encryption? Yes
Options-> Install->change default AP
** Configure NetFront
Options->Settings->Connection
Enable Proxy : Yes
Proxy Host : 192.168.0.x ( in my case x=50)
Now you can browse the internet from your phone.
NOTE: First Configure the phone and your pc without the ** settings, and if you can’t browse the Internet form your phone then use the ** settings.
Hope this works fine.Thank you.
Nov 25, 2008 | Computers & Internet
Would like help with what the optimal gaming settings are
Got free help somewhere else and problem solved
Nov 11, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
