Rexel p210 Door open light is on
Door open light is on and door is not open
Fiat doblo door open light stays on and doors won't lock
this is the door open light indicator on your instrument panel correct? it thinks the door is open. do interior courtesy lights work? i.e. turn on off when opening doors? check for "normally open" circuit faults in the door switches
Aug 27, 2012 | Fiat Doblo Cars & Trucks
How do I open up a rexel stapler?
There's a plastic button on the back of the Rexel stapler that says "press."
May 04, 2012 | Tools & Hardware - Others
I tried to staple too many papers together using my Rexel Staple Wizard, now it won't work - any ideas?
open and check the clip from where the pins come out for staple. may be one or two pins are stuck in it.
Dec 15, 2011 | Tools & Hardware - Others
Rexel RSS1627/RSX1227 Red light always on when
I have an Acco Rexel RSX 1227 shredder. Can you use any oil to oil the shredder or must it be a special oil
Aug 22, 2011 | Office Equipment & Supplies
Hi, I have a Macbook Pro and I'd like to use my ICD-P210 sony recorder: is there any drivers for it? Thanks Imane
Hi imane_bu,
did you find an answer? - I also have a MPB and have been offered the ICD-P210.
Peter
Dec 17, 2010 | Sony ICD-P210 Digital Voice Recorder
When i open the door the light does not come on
Most likely the button on the door jam for the closed door maybe bad. Make sure the selection switch by the light is on DOOR. Then if the button is working, the open door symbol on your dash display should light up with the door open.
If it doesn't light up on the dash display with the door open, then the button on the door jam is bad.
Oct 11, 2009 | 2003 Toyota Corolla
Old Rexel 1250 - falsely detecting safety cover is open
You'll have to unplug the machine, then remove the screws front (inside door or cabinet) and rear to remove the top cover. Insure that the safety cover arm which contacts the microswitch is not broken or the microswitch is out of adjustment.
Oct 24, 2008 | Office Equipment & Supplies
Sony IC Recorder icd-p210 how do you turn it off?
The hold button on the right hand side . Just slide it forward and it will go off. forward means if you are holding it, in your hand facing your slide it up ..
Sep 09, 2008 | Sony ICD-P210 Digital Voice Recorder
k24674
jasbo
jasbo
