Question about ACCO Brands Office Equipment & Supplies
Where is the exit paper sensor - ACCO Brands Office Equipment & Supplies
2 Suggested Answers
  • 23 Answers
SOURCE: paper doesn't exit sensor all the way
You need a fuser exit sensor.
P/N 120N00487
Posted on Jun 17, 2009
Erro code e02 in toshiba estudio 181
hello
dear you have to verify all the exit sensor related
1. do u have look on fuser unit drive gears.
2. is the exit rollers are good some time exit roller got damaged they don't hold hold paper to run out from machine.
3. do u have clean the exit sensor.
4. do you have verify that the exit sensor actuator is free to operate the sensor.
5. some time exit sensor actuator broken.
Aug 28, 2014 | Office Equipment & Supplies
Paper jam signal
I know your copier has sensor
1. Paper feed sensor in cassette
2.Paper feed by pass tray sensor
3.Transfer unit sensor
4.exit sensor in fuser unit
5 Paper exit sensor duplex unit
may be any sensor displace or broken
its open
please check it and fix problem
Jul 14, 2012 | Canon imageRUNNER 210S Copier
201.08 paper jam The paper continually jams - I clear it and hit the continue but it jams over and over. there is nothing stuck in there!!
201.08
Description
Exit sensor is never made.
Possible causes:
• Improper loading of manual feed slot
• Paper wrapped in fuser
• Damaged paper exit sensor or paper exit sensor flag
• Damaged fuser autoconnect
• Faulty fuser DC cable connection
• Faulty fuser
• Faulty system card
Action
• Check for anything in the paper path that might cause the paper to jam.
• Load paper in the manual feed slot.
• The fuser exit sensor may not be functioning properly.
Jul 14, 2011 | Lexmark C530dn Laser Printer
CANNON PC745 SAYS PAPER JAM. NO PAPER JAMMED.
The problem is normally on the exit sensor.Please check the exit sensor if its in the right possition.If the exit sensor is in the right position,also check the registration sensor if its sitting in the right position.Normally the problem is that the sensors (either the 'exit ' or 'registration' sensors) will be not in their correct position.If the two sensors are ok,there should be a small paper lleft in the machine
Brighton2m
Apr 16, 2010 | Canon Office Equipment & Supplies
Canon PC745. Power On button works intermittently, and paper continues to jam. What parts do I need? Where can I find them? Thanks!
It has two paper sensor .Paper feed sensor or paper exit sensor.Paper exit sensor inFuzer unite. It ma by displace or broken.check it and fix your problem.
Dec 27, 2009 | Office Equipment & Supplies
Hi having this printer error. Hope you can
Fuser Exit sensor is never made.
Possible causes:
Gerrit Jan
Nov 05, 2009 | Lexmark C534N Printer
Paper jam, but no paper in the machine
This one is easy, its yoru exit sensor, the only sensor in the scanner "looking" up, so dust sits on it untill it thinks its paper. slide in a cotton bud or blow air in the small recess between the 2 black exit rollers visable where the paper exits from.
let me know how you get on.
Jul 15, 2009 | Panasonic KV S2026C Path-Through Scanner
Lock down
Is sounds like your exit sensor actuator has been knocked off. It's not seeing the paper hitting the exit sensor and shutting down.
May 08, 2008 | Xerox Phaser 8200 Laser Printer
Paper jam at fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present
Verify that the fuser exit sensor is not stuck
If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest.
Dec 04, 2007 | Xerox Phaser 7750DN Laser Printer
26 people viewed this question
Top ACCO Brands Office Equipment & Supplies Experts
Adorjani Laszlo
Are you an ACCO Brands Office Equipment and Supply Expert? Answer questions, earn points and help others
