Question about Haier 24 in. ESD100 Built-in Dishwasher
Location of thermal fuse on intergrated whirlpool 722 dishwasher
    Scholar:
    New Friend:
  • 111 Answers
Are you talking the thermal fuse for the control it is located in the control panel behind the door panel
Posted on Feb 15, 2014
Anyone know how to replace fuse on dishmaid 3?
Normally fuse location would be on the inside of the case of dishwasher follow the power cord in a will be on a board attached to it.
Oct 30, 2016 | Dishwashers
Whirlpool Point Voyager Dishwasher blows thermal fuse - pump motor draws 10A
Yes 10amp seems a lot of current being drawn by the pump motor. Not sure if it is safe to run dishwasher in this condition. One reason could be a leaky capacitor on the motor. Try to replace it. See item 26 on http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-GU1500XTLB0/1198/0130000/W0503069/00008
Apr 04, 2014 | Whirlpool Dishwashers
Why thermal fuse is blown
If you have no power to your machine and the power is on it is the thermal fuse. If the fuse is blown you will get no power at all. To my understanding after talking to many people the thermal fuse is likely the first thing to go bad on a whirlpool dishwasher. A power surge to your unit would cause the fuse to blow or the control board to go bad.
Jan 13, 2013 | Whirlpool 24 in. DU1100XTPS Built-in...
My Whirlpool dishwasher was running when there was a power failure, and now there is no power whatsoever. The power failure happened when the machine was on final rinse and drain. Water is still in the...
Most Whirlpool manufactured dishwashers have a thermal fuse, located inside the operator console. When tripped, the dishwasher will not run. A power outage can cause the thermal fuse to trip. It cannot be reset and has to be replaced, if bad. Please post back with your COMPLETE MODEL NUMBER (located around the door opening) so I can determine the configuration of your dishwasher and explain how to access any potential fuses. -->
May 19, 2011 | Whirlpool Dishwashers
Whirlpool DU1055XTSS dishwasher is totally dead as if it were unplugged. No response from front lights. Only 3 years old. Another post for an different Whirlpool model says it's the thermal fuse, but I...
If you have power going to the dishwasher, meaning the breaker, switches, wiring and fuses in the home are okay, the most common cause for your symptoms is the thermal fuse.
The thermal fuse is a small disk shaped device that is behind the control panel on the right side it is snapped on to the electronic module. The part number for your model is W10258275
Jul 24, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
No power going to front panel on whirlpool dishwasher gu2455xtsso
If the model number you listed this question under is correct, there is a thermal fuse (also known as a bi-metal) located inside the control panel of the dishwasher. The part number for the thermal fuse replacement is W10258275.
If you type in your model number you can utilize the exploded view parts diagrams at pcappliancerepair.com, appliancepartspros.com or searspartdirect.com to assist you in locating the part. The fuse is listed as item 6 under the "Control Panel Parts" section.
To replace the fuse, follow these steps:
1. Make sure the dishwasher is unplugged or the breaker is turned off.
2. Open the door and remove only the top screws directly behind the control panel.
3. Remove the protective cover from back of the control panel to expose the main control board.
The thermal fuse should be mounted to the control board. If you remove it and take a resistance check, it should read close to 0 ohms, if good. If bad, replace as necessary.
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Apr 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher not starting
There is a thermal fuse located in the control panel that is probably blown out.
Open the control panel by removing the 6 screws around the top inside of the door. The thermal fuse is located on the top right side. Remove the wires from the fuse. Use a volt neter set for continuity to test the fuse. No reading is a bad fuse.
This link will show the fuse.
http://www.appliancepartspros.com/part_details.aspx?part_id=3115186&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5162747%26diagram_id%3d914101
Jan 03, 2010 | Whirlpool 24 in. DU930PWP Built-in...
Completely dead. breaker is fine. have live power at dishwasher. ???? Replaced heater, pump and check valve last year. No obvious burnt or disconnected wires.
There is a thermal fuse located behind the operator console on nearly all Kenmore or Whirlpool manufactured dishwashers. There were some noted problems with certain model dishwashers where the wire gauge on the thermal fuse was too small and would heat up causing the thermal fuse to blow prematurely. There is a replacement kit available that includes a wire harness with a larger gauge wire that you simply splice in place. It handles current better and prevents the fuse from blowing prematurely. To ease your mind, there were no reports of fire hazard.
If you need to view a diagram of your dishwasher, enter your model number at the website mentioned for some excellent exploded view illustrations. The thermal fuse is usually listed under the "Control Panel Parts" heading.
If you have any questions, please let me know. I hope this helps you.
Oct 15, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Does the whirlpool GU1500XTLS1 have a fuse - I do not have any power to the console?
Yes, there is a thermal fuse located behind the operator console. The part number for the replacement kit is 8193762. You can view an illustration at appliancepartspros.com. It sells for about $13 and the instuctions with a wiring harness are included with the kit.
NOTE: You MUST follow the instructions and use the wiring harness. There were some noted problems with certain model dishwashers2.gif where the wire gauge on the thermal fuse was too small and would heat up causing the thermal fuse to blow prematurely. The replacement kit includes a wire harness with a larger gauge wire that handles current better, preventing the fuse from blowing prematurely. To ease your mind, there were no reports of fire hazard.
If you need to view a diagram of your dishwasher, enter your model number at the website mentioned for some excellent exploded view illustrations. The thermal fuse is listed as item 6 under the "Control Panel Parts" heading.
Oct 06, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Haier 24 in. ESD100 Built-in Dishwasher Logo
55 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
