Question about KMD Komodo Shockwave Wireless Black Controller for Wii and Gamecube
How do i install my shockwave wireless controller on my wii? Dont know where to plug in sensor
I don't know where to plug in sensor
How can i connect my wii thru my wireless?
  • instructions on how to connect wii thru your wireless
    Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
  • 2
    Press the "A" button on your Wii controller to continue from the warning screen.
  • 3
    Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
  • 4
    Click the "Wii Settings" box on the right.
  • 5
    Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
  • 6
    Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
  • 7
    Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
  • Dec 06, 2011 | Nintendo Wii Console
    DO YOU HAVE TO HAVE THE USB PLUG FOR THE ROCKBAND DRUMS FOR THE WII AND HOW DO YOU SYNC IT TO THE WII?
    Yes, you do need to use USB for rockband drums for wii, but i don't know how to sync the drums, if they're wireless, if it's a wired set, just plug it in the back of the console, i know how to sync a wireless guitar, on the part you plug into the wii, there should be a tiny white button, and the guitar should have a white button on it, push both buttons at the same time (make sure that thee guitar has batteries and the other is in the wii), if done correctly you should be able to play, if the wireless drums work like that too, than i hope this info helped.
    May 07, 2011 | Nintendo Rock Band for Wii
    Just want to know how to install the bar with my wii
    1. Unplug the nintendo sensor bar from the wii
    2. Make sure the Nyko has 4 good AA batteries.
    3. Place the nyko bar where you had the nintendo sensor bar and turn on.
    4. Dont forget to turn off the wireless bar when you are done playing a game.
    Mar 01, 2011 | Nyko Wireless Sensor Bar IR sensor
    Dont know how to link to controller
    I don't know how to link a wireless nunchuck but you probably have to hit the button on the wii remote where the batterys are and if there's some sort version of that on the wireless nunchuck then you probably would have to hit that and the wii remotes one and pray for the best.
    Hopethis works cause if it doesn't well I don't know.
    :0
    Jan 31, 2010 | Exponet Wireless Nunchuck for Nintendo Wii...
    Wii sensor bar wont work
    try unpluging the cord connecting to the wii sencor bar for 30 sec.
    Sep 19, 2009 | Nintendo Wii Console
    Guitar does not work with guitar hero and everything freezes
    you have to open the thing on the wii where you put the SD card, and there will be a red button. Press it. Then, plug in the remote to to controller, open the battery compartment and press the red button. This should sync the remote to the wii. In the future you have to plug in the remote to the controller BEFORE the wii is turned on. As for your second problem i dont know.
    Feb 08, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
    The wire of the nintendo wii sensor is riped
    well that basicle means that you cant play your wii because your wii motes cant register to the wii. wii sensor bars are pretty cheap and if you dont want the hassle of wires everywhere then you can just get a wireless sensor bars that are pretty pricy but not too bad. the downside of a wireless sensor bar is that the connection isnt that great and it drains battery life life CRAZY.
    Oct 17, 2008 | Nintendo Wii Console
    Flash 9 freezes after 1st. video plays on The Fan.
    Lets Start from here:
    Before you install Shockwave Player for any Windows browser, uninstall all previous versions.
    In order to remove the Shockwave player, simply use the file UNWISE.EXE located in C:\WINDOWS\system32\Adobe\Shockwave 11. Windows users can also use the Add/Remove programs located in the Windows control panel. This will remove the Shockwave 10 player
    For the Shockwave 8 and 8.5 there is an uninstaller available from the Web Players page.
    Note: All applications must be closed before you run the Shockwave Player uninstaller. Quit all running applications, including all Internet Explorer or other browser windows, and all Instant Messenger clients. Check the Windows system tray carefully to make certain no applications which might possibly use Shockwave Player are still in memory.
    After you have removed previous versions, you are ready to download and/or install Shockwave Player.
    Before installing Shockwave Player, please check the following browser settings:
    Internet Explorer ActiveX settings
    Browser security settings should be chosen by you or by your system administrator. For single users who do not have an administrator, the Medium: Default Level allows you to view Shockwave content. For any Custom Level, ensure that both the "Download Signed ActiveX controls" and "Run ActiveX controls and plug-ins" options are set to "Prompt".
    To change security level in Internet Explorer:
    1. Open Internet Explorer.
    2. Choose Tools > Internet Options.
    3. Select the Security tab.
    4. Select Custom Level.
    5. Find the section "ActiveX controls and plug-ins".
    6. Set ' Download Signed ActiveX Controls' to Prompt.
    7. Set 'Run ActiveX Controls And Plug-ins' to Prompt.
    If you are having trouble installing, make sure that your Internet Explorer security level is not set to High or to a custom level that does not allow viewing of ActiveX controls.
    Computer user permissions
    User permissions determine whether or not you are allowed to install ActiveX controls or plug-ins. If you don't have Administrator access to Windows XP SP2, or Vista you may not be able to install Shockwave Player successfully. Administrative privileges are required for the Windows system registry and for the C:\WINDOWS\system32\Adobe\Shockwave folder.
    If the ActiveX Control for Shockwave Player fails to install, download the executable installer.
    If the information above has not resolved the issue, download the executable Shockwave Player installer here:
    * Download and latest Shockwave Player Installer.
    Save this installer to your desktop, close out all applications, and run the installer. This may help if you are having trouble with the ActiveX installation from Adobe.com. To confirm that Shockwave Player has installed successfully, please click here. The two movies will show if you have Flash and Shockwave Players installed. The version numbers of the both Players will be displayed in the test movie.
    Apr 16, 2008 | Computers & Internet
    KMD Komodo Shockwave Wireless Black Controller for Wii and Gamecube Logo
    73 people viewed this question
    Top KMD Video Game Consoles & Games Experts
    James Wishart
    Are you a KMD Video Game Console and Game Expert? Answer questions, earn points and help others
