Question about Canon Office Equipment & Supplies
Specified Paper Different from Set Paper canon 6200d
How do i get my canon pixma mg7550 printer to detect photo paper in cassette 1
Unless it has an autodetect feature, that is typically a used specified item in the set up or properties.
Jan 01, 2015 | Canon Office Equipment & Supplies
How do I clear the in use alarm on a canon mx340 printer?
The in use alarm appears to be related to fax reception and printing. There are some options below that you could try:-
Memory Reception If the machine receives a fax under one of the following conditions, it will not be able to print the received fax and will store it in its memory. The In Use/Memory lamp is lit and Received in memory is displayed on the LCD. When the problem is resolved as described, the fax stored in memory is printed automatically.
  • Ink has run out: Replace the FINE Cartridge.
    i_green_arrow.gifRoutine Maintenance
    i_note_e.gifNote
    • You can set the machine to forcibly print a received fax even if the ink has run out.
      However, part or all of the fax may not be printed since the ink has run out.
      Also, the contents of the fax will not be stored in memory.
      If the ink has already run out, we recommend that OFF be selected for Auto print in FAX user settings to store the received fax in memory and print the fax manually after replacing the FINE Cartridge. After you replace the FINE Cartridge and select ON for Auto print, the fax stored in memory will be printed automatically.
  • Paper has run out: Load the paper and press the OK button.
  • A different size of paper from that specified by Page size is loaded:
    Load the same size of paper as that specified by Page size, then press the OK button.
  • Page size is set to other than A4, 8.5"x11"(LTR), or Legal (or 8.5"x14"):
    Set Page size to A4, 8.5"x11"(LTR), or Legal (or 8.5"x14").
  • Media type is set to other than Plain paper:
    Set Media type to Plain paper.
  • You pressed the Stop button to cancel printing of a fax:
    Press the FAX button
Alternatively turn the printer off, open the devices and printers section of Control Panel, right click on your printer and select "see what's printing" and left click on this. A window will pop up which may or may not contain a list of documents. If it does these must be cancelled (Menu - Printer - Cancel all documents). Once all documents have gone from the list turn the printer on and try to print.
Other than the above suggestions I would need to know more about your OS and exact problem. Hope this helps.
Aug 06, 2014 | Canon PIXMA MX340 Wireless Office...
Canon load correct paper
•When copying or printing received faxes, check the following:
1. Paper loaded in the machine
2. The paper size specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
•When printing from a computer, check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Oct 15, 2013 | Office Equipment & Supplies
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the paper in the paper cassette or multipurpose tray is different from that of the paper specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>. You need to load the correct size paper or change the paper size in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 16, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
Can i use glass type paper (used for OHP) in canon LBP 2900B
you can do it , but avoid continuous usage. You should go to printer property,page settings and change the paper type to transperancy. the gsm of paper will be specified there.
Never use butter paper.
Apr 10, 2011 | Canon LASER SHOT LBP-2900 Printer
How can i make my mp460 printer wireless
If you are using Windows follow these steps:-
Printing with Computers (Windows) via Bluetooth – Windows
  • Note: A different screen may be displayed depending on the application you use. This section gives a description using the screens displayed under Windows XP SP2.
  • Bluetooth communication distance: Approx. 10 meters in normal environment.
1. Turn the printer on and load paper.
2. Create a document or open the file you want to print.
3. Open the Setup tab of the printer driver.
(1) Select 'Print' from the File menu of the application
The Print screen appears.
(2) Select the printer to which you attached the Bluetooth unit such as Canon XXXXXX (Copy X) .
  • Note: "X" is a device name or a digit. The number of Xs varies depending on the device name.
(3). Click 'Preferences' (or Properties).
4. Make settings necessary for printing.
(1) Select a media type from Media Type.
(2) Click 'OK'.
  • Note: To check the paper size, click the Page Setup tab. If it is different from the size specified with the application, select the same size as that specified with the application.
5. Start printing.
(1) Click 'Print' (or OK).
Feb 16, 2010 | Canon PIXMA MP460 All-In-One InkJet...
A3 manual copier is not working
1) did you set the right format and type of paper on display?
2) Clean the roller or replace it
3) see if there is any sensor broken or plastics
4) if nothing helps pls send the more specified question
Jan 12, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
4050tn paper tray setup
This is specified by the print driver. Go into the printer configuration or print properties of you have a windows box, and set the trays there - accessories or paper tab.
Apr 10, 2009 | HP LaserJet 4050tn Printer
Paper will start through printer
i think its asking if you are using right kind of paper specified to be used with your printer there are alot of different types of thickness in paper out there make sure your using the right one
Jun 02, 2008 | Canon BJC S600 InkJet Printer
207 people viewed this question
old marine
old marine
