Question about Irons
How to fill the water tank of an elna 340 steam iron
I cant remove the black rubber dome
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
DiYerTech
  • 70 Answers
SOURCE: no steam comes out of iron
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
Posted on Jul 21, 2008
SOURCE: Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Posted on Sep 03, 2008
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Posted on Oct 07, 2008
What could be stopping the water in the holding tank not going in the steam tank on my Perfect Care Iron ?
most likely is mineral build up. drain out the water and replace with white vinegar, warm up the iron and allow it to sit until you see steam (several minutes to half an hour) if no steam, replace the iron.
Jun 18, 2014 | Irons
How do i descale it
Fill the tank with regular malt vinegar and leave it overnight, Was out in the morning and should have removed most of the scale. Then mix two parts vinegar and one part water and fill the tank again. Heat the iron up to max setting and steam through to remove any small deposits in the steam holes. Repeat if needed.
Feb 27, 2011 | Philips HI-296 Iron
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
How to put water in the Tefal pro 2500
This type of iron is called a steam station iron.
The box is the water tank and it is this that you need to fill with water. You should be able to find a small spout on the water tank in order to fill it. These irons produce a huge amount of steam and should make the ironing a breeze once you get used to it.
Feb 07, 2009 | Tefal Irons
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Sep 09, 2008 | Rowenta Steam Generator DG050 Iron
Rust
A few cheap n easy ideas I hope will help you...
  • You could try using a car radiator flush treatment such as rust & scale inhibitor to flush the water tank.
  • Fill water tank with Coca-Cola . Let it soak at least overnight and rinse out thoroughly.Think im crazy? Leave a old coin in a glass a coke for a few days and see what happens!!
  • Refrain from using tap water to fill the iron. Use distilled water ,it's has less of the impurities that cause rust and other metal-oxides forming
  • If all else fails use a small spray bottle of water on the clothes that are at most risk of being soiled.
That way you can add fragrance oil or other things to the water that would normally get boiled off /or pollute the water tank :)
May 26, 2008 | Black & Decker Steam Xpress AS250 Iron...
Thanks J
Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
Water drips out of steam holes
I suspect that by placing it on its heel rest the water from the tank is not allowed to enter into the steam chamber and when you go into ironing mode there is a rush of water that is cooling down the sole plate to below steaming temperature. Try keeping it in the horizontal position on a heat proof pad and press the steam button just before going into ironing mode.
Sep 08, 2007 | Panasonic NI-H10NS Iron
Irons Logo
50 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
