Question about KMD Komodo Shockwave Wireless Black Controller for Wii and Gamecube
How do i install this controller on my wii. Dont krow where to plug in sensor
I have a Wii game system model No. RVL-101 (USA) how do u get it to work
ok so u start to plug all the wires in the TV.theres a sensor that u need to put in middle of the tv.the sensor is like a rectangle and very lite its supposed to have a wire that has to be plugged in the wii not the TV.
after that its time for your controllers.you need to have at least one controller to play wii.you need to put two batteries at the back of the controller.then click the power button and you'll see the 4 lights light up,but then after seconds there supposed to be 1 light lit up.when your done than click the power button for the wii.for the controller to work u should turn on the wii before the controller.Then the easy part take the cd(game)and put it in the wii.
Dec 06, 2013 | Nintendo Wii Console
We have a Nintendo Wii and no the remote controls aren't working with the console. Ihave tried replacing batteries. Do I need new remote controls or a new charger for the controls?
If your remotes are showing power lights at the bottom when you press buttons, then you may have a problem with the sensor bar that receives signals from the remotes.
First, try unplugging and plugging back in the sensor bar to the Wii. If it still doesn't work, the next step would be to replace the sensor bar. You can find them just about anywhere you buy Wii accessories and they are fairly cheap.
Mar 02, 2011 | Nintendo Wii Console
I just bought a ultra wii sensor bar and i cant hook it up.. i need directions i have looked everywhere and i cant find the simple directions i put the batteries in and now i dont know what to do please...
Greetings,
The sensor bar cord plugs into the Wii sensor connector in the back of the Wii. I have posted the Wii manual here. If your having trouble, refer to pages 13-16 in the manual. Thank you for using FixYa! =)
Nov 21, 2010 | Video Game Consoles & Games
How do I register The Wii Classic Controller. I have no number that came with my Wii classic controller so I cant register it on my club Nintendo account.
Um....you dont register the Wii Classic Controller. Pretty much just plug it in the controller and use the Wii Classic Controller and play the game.
Jan 17, 2010 | Nintendo Classic Controller for Wii
Wii remotes dont work on the tv screen replaced batteries in both remotes still does nothing
If you ahve checked for all possible obstructions or made sure tha tyour sensor bar is plugged try to re-sync your Wii remotes. Unplug your Wii for about 30 seconds and then plug it back in. Upon seeing the health and saftey screen hold down the sync button on your Wii console for 15 seconds. This clears out any previous Wii Remote Syncs. After that is performed open up the battery cover on the Wii remote you want to sync and hit the red button, soon after you do that hit the red sync button on your Wii Console. If it syncs properly the blue LEDs on the bottom of the controller will corespond to the # remote it has been synced to. Good luck.
Dec 29, 2009 | Nintendo Wii Console
Cant get signal for menu to operate on wii
make sure the thing is plugged in the back and try the wii seettings and give me a good rating please
Nov 16, 2009 | Nintendo Wii Console
Remote dont work. lights just flash. tried to sync did not work. Bought a new remote and went to sync it now it is doing the same thing the other remote did> Any suggesions?
Basic Question: Did you set up the sensor bar?
I'm assuming you follow the instructions to plug in the Wii and to attach the sensor bar to the console and position the sensor bar so it is either below or above the television.
The Wii remote flashes (more specifically the bottom row of four lights that indicate which player each remote belong to flashes) when a button is pushed on the control while the Wii is off.
If the Wii is on and simply sleeping (as evident by a blinking yellow light on the power button on the console) pushing the power button the control should turn on both the console and the remote. Be sure to aim the remote at the console when "waking" the Wii up and at the sensor bar once the Wii Menu loads. The remotes automatically turn off with lack of interaction.
To recap: Your remotes sound to be working fine. I would assume it might be a problem with the interaction between your console and the remotes or the setup of the console. The Wii Information Guide has pictures and pretty clear connection instructions that should help fix your problem.
If everything is set up correctly as per the instructions and your system still does not interact your sensor bar may be faulty or your console as I believe you're remotes work fine.
Jun 26, 2009 | Nintendo Video Game Consoles & Games
Wii problem
did you try to resync the remotes and board?
Apr 27, 2009 | Nintendo Wii Console
Ddr mat not working properly
Try making sure that the DDR mat is plugged into the FIRST controller jack (there are 4). That is the only way that it is associated with controller 1. If you plug it in any of the other controller jacks, you will be able to use the mat with instructions, configuration, etc., but not to dance. Hope this is your problem! -GeoffM
Dec 23, 2008 | Konami Dance Dance Revolution Hottest...
HELP PLEASE!!!!!!!
I've had this same problem. Remove the batteries from the remotes. Then disconnct the power cord from the back of the Wii and disconnect the power cord from the wall. Let it sit for 5 min. Double check that the sensor bar is plugged into the Wii and check the cord for any breaks that might stop the signal. After you are sure that the sensor bar is connected and the 5 min. have gone by plug it all back in, install your batteries and re-sync it.
Mar 28, 2008 | Nintendo Wii Console
KMD Komodo Shockwave Wireless Black Controller for Wii and Gamecube Logo
62 people viewed this question
Top KMD Video Game Consoles & Games Experts
James Wishart
Are you a KMD Video Game Console and Game Expert? Answer questions, earn points and help others
