Question about RiCOMA 4-in-1 Multifunction Heat Press Transfer Machine
Operating instruction manual for Ricoma HP-0401MF 4 in 1 Digital Mug Plate Hat Tshirt Heat Press Machine
I have a second hand Yamata FY7568 sewing machine, and the bobbin tension is too tight. The instruction book says it is factory set and does not need to be altered. What can I do, please?
I was also looking for yamata manual can:t get it on internet but got it from Ricoma you can mail them on service@ricoma.us and the will send u the pdf file may be a fee if you didn:t purchases the machine from one of there dealers
May 08, 2017 | Yamata Sewing Machines
What does brewing time off mean
You can try the reset for the B60. I do bot understand your original What does brewing time off mean??...
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
Jul 02, 2014 | Keurig B60 Coffee Maker
Why is my Kuerig B60 coffee maker not filling the correct amount of water. ie. a cup instead of a mug or 2 instead of 3rd level?
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar
into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
DO NOT USE A K-CUP
, just press the BREW Button. Pour the contents of
the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until"ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the
Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
water brew cycle. Pour the contents of the
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew
cycles if you notice any residual taste.
NOTE:
If "DE-SCALE" is still displayed after
completing the procedure, repeat the
descaling procedure above.
Apr 14, 2013 | Coffee Makers & Espresso Machines
Keurig b60 won't dispense water
PREPARE
Step 1:
Step 2:
FILL AND CLEAN
Step 1:
Step 2:
DO NOT USE A K-CUP
Step 3:
is indicated.
Step 4:
Step 5:
RINSE
Step 1:
Step 2:
Step 3:
Step 4:
NOTE:
Dec 14, 2012 | Keurig B60 Coffee Maker
I have the B60 model. It has been wonderful from day one and then...today...I made 2 cups this morning, went back about 2:00 to make another and it was off. Hummm...so I tried to turn it on and it will...
Try the following steps to reset the processor:
1. Simultaneously press and release ?small mug? and ?medium mug?. Immediately afterward press ?menu? 3 times. You should see a time 6:09 (or similar) on your screen.
2. Press ?menu? once. Your LCD screen should say Brew 0:00.
3. Press and hold ?medium mug?. While holding ?medium mug? press and release ?menu?. Immediately after releasing ?menu? (while still holding ?medium mug?) press ?small mug?. Release ?small mug? and ?medium mug? at the same time. This entire thing needs to be done very quickly.
4. Unplug the machine (do not turn it off). Wait for 3 minutes or so. Plug it back in, turn it on and follow the instructions for priming.
Jan 05, 2011 | Keurig B60 Coffee Maker
Our Keurig B60 displays "NOT READY Auto off set" and does nothing. What can we do to bring it back to life?
Press the off/on switch and poof on the machine and then check. If that is not helping then try this procedure as follows:--- 1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen .) You should see a time 6:09 on your screen.
--------- If this instructions also not helping then try this, instead of holding the medium cup while pushing and releasing menu .you simutaneously push and release medium cup and menu and then medium cup and small cup and then check out. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Aug 28, 2010 | Keurig B100 Coffee Maker
When I turn on my Keurig Brewer B60 It says not ready. It doesn't pull water to heat it and it shuts off after about 3 minutes.
Normal 0 0 1 94 537 4 1 659 11.1287 0 0 0 Try the following steps to reset the processor:
1. Simultaneously press and release “small mug” and “medium mug”. Immediately afterward press “menu” 3 times. You should see a time 6:09 (or similar) on your screen.
2. Press “menu” once. Your LCD screen should say Brew 0:00.
3. Press and hold “medium mug”. While holding “medium mug” press and release “menu”. Immediately after releasing “menu” (while still holding “medium mug”) press “small mug”. Release “small mug” and “medium mug” at the same time. This entire thing needs to be done very quickly.
Mar 29, 2010 | Keurig B60 Coffee Maker
Brew lit, but "not ready" lit solid "not flashing" fix
There are 4 steps to fix this:
Aug 10, 2009 | Keurig B60 Coffee Maker
Resetting Pin on Blue Hat ATM machine
Hi abbeybath,
We have the same atm/bank for our son. Here's the fix:
1 - push the reset button on the back of the ATM near the battery compartment.
2 - insert the ATM card and press the BALANCE button to change the user name (need to do this before getting to the pin)
3 - enter your childs name and push enter when complete. Cancel will delete an incorrect letter.
4- enter the default pin (1234) - this will bring up the DEPOSIT, WITHDRAWL, BALANCE screen.
5 - Press ENTER and it will show the current/default pin. Input the new pin number you desire and press ENTER again.
All set. Hope this helps!!
Jan 17, 2009 | Blue Microphones Blue Hat Little Shots...
REPAIR TSHIRT TRANSFER HEAT PRESS
i am very familiar with this item
i know the people in china that makes them. email me at itemsgalore@gmail and i can get you in the direction of the schematics and the specification for all the units
Jul 25, 2008 | Kitchen Appliances - Others
RiCOMA 4-in-1 Multifunction Heat Press Transfer Machine Logo
112 people viewed this question
Top RiCOMA Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a RiCOMA Craft and Hobby Expert? Answer questions, earn points and help others
