Question about Samson Servo 120 Amplifier
Fuse How to change a fuse on servo 120a
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: fuses keep blowing on my
If after putting in the right rating of fuse you have a blow out, then you must diconnect the speakers and test. If the fuse hold ok then the speakers must be checked for shorting or fault in the network. However if the fuse still blows off, then you will need to take out the cover to test within the main board for the power section or output section malfunctioning. First of all discconnect the power to the output stages and test, if fuses blows check the powersuppy section, the rectifier to the main capacitors for reduced values. If not check on the output stages, the drivers, the predrivers for malfunctioning. However you will need some knowledge of electronics to probe stage by stage to isolate the fault.If not get help to proceed. Good day
Posted on Aug 04, 2010
Need to know where the inline fuse is located on a 2000 camrry ce ignition switch
There are three fuses involved that supply the ignition switch voltage, the 120A alternator fuse, this fuse powers the smaller AM1 and AM2 fuses, then the voltage goes from there to the ignition switch
Mar 06, 2018 | 2000 Toyota Camry
Does a 2005 kia sedona have a alt fuse,,if so where is it,,battery and brake light comes on while driving
The alternator is protected by the 120A MAIN FUSE in the engine compartment fuse/relay box.
Sep 17, 2016 | 2005 Kia Sedona
The part nummer to the fuse 120a 4runner 2001
Contact a Toyota dealer parts department and they will look it up for you.
Apr 28, 2016 | Toyota 4Runner Cars & Trucks
Hooked cable up wrong i think i blew the main fuse
Open fuse box under hood, inspect main fuse probably blown. May be labeled 80A,100A or 120A.
Jan 25, 2014 | 1991 Honda Accord
Bolts behind the bracket from 120a main fuse mazda
-Why don't you just up load to this web site. There are many peoples here can share their experience with you.
Good luck
Mai
Dec 12, 2017 | Mazda RX-8 Cars & Trucks
No sound coming with protection light on
It's either overheated or you may have faulty speaker wiring or a shorted speaker. These directions come from a Samson servo 120a but the theory is the same.
The following conditions will cause the Protection LED to go on:
Initial power-up: For approximately five seconds after initial power-up, the relay
speaker connection circuitry is deactivated and the speaker output is muted. If everything is operating normally, you will hear an audible click at the conclusion of this brief period, as the circuitry is activated and the Servo 120a begins delivering signal to connected speakers (at which point the Speaker LED will light if the Speaker on/off switch is in its "in" position). It is normal for the Protection LED to fade gradually after the amplifier is powered off.
Overheating: A temperature sensing device in the Servo 120a will cause the relay speaker connection circuitry to be activated (and the Protection LED to go on) whenever the operating temperature of the unit rises above a safe level. To guard against this problem, make sure the Servo 120a receives adequate ventilation on all sides ; in extreme environmental conditions, you may also
want to consider the use of cooling fans.
Severe overcurrent conditions: This occurs whenever the signal being output
from the Servo 120a rises to a level above 20% THD (Total Harmonic Distortion).
Shorted speaker cables: This will occur if, due to faulty wiring, the hot and ground signals being output by the Servo 120a short to one another.
Output impedance drops below 2 ohms: This can occur if the Servo 120a is connected to inappropriate speaker systems (see the "Setting Up and Using the Servo 120a" section in this manual for more information).
DC voltage detected at speaker output: The most likely cause of this is an internal failure. In general, any time the Protection LED lights up (other than during the approximately five seconds following initial power-up), there is reason to be concerned. If this occurs, turn the Servo 120a off immediately and carefully check all wiring and external devices in order to locate and correct the condition that caused the LED to light up in the first place.
Dec 27, 2010 | Samson Servo 170 Amplifier
Fuses keep blowing on my Samson Servo 120a
Aug 03, 2010 | Samson Servo 120 Amplifier
Where is battery fuse link
Under hood box: Fuse 20 (120A)
Hope this helps.
Nov 12, 2009 | 1999 Honda Odyssey
Remove fuse 120a
You cannot change the fuse the way that you are trying. You need to loosen all of the bolts that holds the fuse box to the inner fender, and then observe the sides of the box, there are tabs that allow the exterior/bottom of the box to be pulled DOWN. After the box bottom is released, the 120 Amp fuse is accessible.
Hope this helps.
Dec 07, 2008 | 2004 Toyota Solara
44 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
