Question about Dell Vostro Computers & Internet
Error code 2000 0146
Diagnostic short test message code d'erreur 2000-0146
Geekman
  • 32281 Answers
SOURCE: D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Posted on Feb 17, 2009
pa1nkiller
  • 68 Answers
SOURCE: DST Short Status Test. Error Code 1000-0146
sounds like your hard drive my need changing
Posted on Aug 21, 2009
Vaio Tech
  • 166 Answers
SOURCE: Dell latitude d610 DST Short Status Test 1000-0146 and 1000-014
try to change out the hard drive on the notebook whid a similar one the size of the hard drive can not be over 160 gb and reinstall windows if it work you may be loss your hard drive
Posted on Oct 10, 2009
  • 3940 Answers
SOURCE: Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Posted on Jan 27, 2010
  • 356 Answers
SOURCE: confidence check error code 1332 device
Hi there!! It seems like you have a fried hard drive. Check the warranty of your system and have the hard driver replaced.
^_^
Posted on Jun 03, 2010
Message d'erreur code 11:11
Error code indicating that Trailing cable faulty, replace it. But technical skills required to replace this spare..
Dec 14, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
Tip
Beep codes
Diagnostics with Beep Codes Following are the beep messages associated with the IBPbios. 1 short beep specifies a normal post 2 short beeps tells about POST errors that can be find onscreen. Continuous beeps indicates power supply and other cardserrors. One long and short beep indicates system board problems 3 long beeps defines keyboard errors No system beep tells about power supply errors.
on Mar 15, 2011 | Computers & Internet
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
No heat coming out fan blows but no heat
there's a blend door actuator behind the dash. they are going bad all the times. however, check your coolant level first.
Feb 28, 2010 | 1996 Lincoln Town Car
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Aug 16, 2009 | Dell Latitude D610 Notebook
Feb 17, 2009 | Dell Latitude D610 Notebook
Self diagnostic test codes
anytime you do the self-diagnostic you will almost always get those 2 codes.
12 - direct power input to the PCM has been disconnected within the last 50 key-on cycles
55 - End of error messages
Dec 27, 2008 | 1997 Mitsubishi Eclipse
Whirlpool front loader door locked
My Tech sheet reads F01 is a EEprom Error ? Unplug washer or disconnect power for at lease two minutes. EEPROM ERROR A communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred. Possible Causes/Procedure ■ A power glitch may cause this error. ? Verify CCU operation by running a Diagnostic Test or any cycle. PUMP DRIVE ERROR The pump driver fails to activate. ■ Replace CCU board. MAIN RELAYS ERROR ERREUR - One of the main relays is not working properly. Possible Causes/Procedure ■ The relay might be soldered or always open. ? Replace CCU board. Good luck and let mre know what you come up with
Sep 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Computers & Internet Logo
20 people viewed this question
Alun Cox
