Question about Wagan 400 Watt Power Dome
Charging indicator stays on - Wagan 400 Watt Power Dome
CHARGING HOW LONG
Blue Light staying on is a sign that it is in pairing mode. Depending on your headset the charging indicator is different. Consult your owners manual or http://www.motorola.com/support
Mark
Motorola Support
Jun 08, 2014 | Motorola Radio Communications
How do you recharge jump start system
put a battery charger for a car on the + and - leads and this will recharge it if you do not have the correct power pack recharge transformer
Jan 09, 2012 | Stanley Black & Decker Stanley J5c09 500...
My plantronics explorer 260 won't turn on. Also when I go to charge it the charging light stays on for about a few min. and then shuts off but i still can not turn it on. Please help
Here are a few steps to review before coming to the realization that your battery could be wasted. Give them a try and see if it helps any.
1) While your headset is charging, the indicator glows red. When your
headset is fully charged, the indicator turns off.
2) Turn off the headset: Press and hold the call control button until the indicator glows red. You will hear descending tones. When power is off, indicator stays off.
3) Turn on the headset: Press and hold the call control button until the indicator glows blue. You will hear ascending tones.
Good luck from Headsets Direct!
Feb 24, 2011 | Plantronics Explorer 232 Bluetooth Headset
I've misplaced my users manual for my Stanley J5C09 jump starter
Go to www.baccusglobal.com and link the Stanley link and then the "manuals" link and it should be there
Dec 27, 2010 | Stanley Black & Decker Stanley J5c09 500...
Mp3 will not stay powered on
u should charge your player on a laptop at least for two hours,after charging u will not get this problem
Nov 16, 2009 | SanDisk Sansa e260 MP3 Player
Willnot turn on
Do you know if the charge light blinks when it charges or like mine it stays on untill charged then goes out, if it is blinking when it normally stays on during charging then it could indicate a fault ( usually with the ccd ) and could prove to be a costly repair if not under warranty, maybe worth getting checked out.
Regards
Sharky
P.S. it could also indicate you have a faulty battery or ac adapter
Jul 05, 2009 | Pure Digital Flip Video Ultra Camcorder
Little manual does not indicate to charge unit before using
Hi-the light stays Green when it is fully charged-does not flash-just stays on!
Dec 01, 2008 | Mercury Electronics MP250 (128 MB) MP3...
Warning lights stay on
Brake light warning indicates possible low brake fluid in the reservoir;
Charge warning light indicates battery not charging which can be caused by defective alternator/regulator, slipping belt, corroded fusible link from alternator to battery B+ terminal.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 24, 2008 | 1988 Toyota Pickup
Wagan 400 Watt Power Dome Logo
Top Wagan Welding Tools Experts
Bill Boyd
Are you a Wagan Welding Tool Expert? Answer questions, earn points and help others
