DELL PRECISION T7400 SECOND CPU NOT SUPPORTED
I upgrade my dell workstation T7400 with a second xeon CPU, when I start with win7 the blue screen appear with this massage configuation not supported
    Brigadier General:
  • 3,400 Answers
IF YOU HAVE A PC-Os YOU NEED A SERVER Os.
A PC-LICENSE ONLY GOOD FOR ONE CPU,YOU NEED A
SERVER-Os.I SUGGEST YOU READ SAME ON THE NET ABOUT
IT.
Posted on Feb 14, 2014
Backu
  • 42 Answers
SOURCE: Dell Precision Workstation 670
The 3 beeps is an indicator of, most likely, a memory fault. This could be caused by incorrect memory configuration (unsupported RAM type or speed), not fully seated RAM, or the RAM itself has been damaged in some way. Best advice I can give to you is to open your case and verify that all Memory Modules are fully seated and locked into position. If they are, next step would be to remove all but 1 chip, and try turning it on. If it turns on, then one that you removed is the culprit, if not, that particular module may be the culprit and change it for another. If, after all memory modules tried has not allowed the computer to start, I would recommend taking it to a service center to be checked, as they would be able to verify the MB has not gone bad with using a module they know to be good.
Hope this helps!
-Backu
Posted on Jan 15, 2008
  • 3940 Answers
SOURCE: Hard drive is not detecting intermediately
try a different SATA power connection, sometimes they work loose and this issue occurs.
Posted on Apr 03, 2009
the_fire
  • 432 Answers
Try different memory modules ( RAM ) and see if it is just the RAM.
Also take anything else out you dont need - including dedicated graphics card assuming it has onboard graphics card ( if so then enable the onboard graphics card before taking out the dedicated one )
If its still the same then yes it is the motherboard in which case you need the motherboard replacing.
If you did the diagnostics that they walk you through and they still tell you its the motherboard then it will be the motherboard as there diagnostic software is accurate.
Posted on May 06, 2009
atang1
  • 734 Answers
SOURCE: dell precision workstation t7500 won't boot. Showing solid amber.
You may have to reinstall operating system by buying a Dell cd(from amazon) that reinstalls the operating system you had on the workstation.
Posted on Dec 07, 2011
joecoolvette
  • 5660 Answers
SOURCE: dell precision 470 work station processor fans over speed
Dell Support > Precision 470 Workstation Desktop PC > Users Guide,
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/index.htm
Tools to Help Solve Problems > Diagnostic Lights,
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/advtrbl.htm#wp1057482
"A possible VRM 0 has occurred"
VRM = Voltage Regulator Module
Here is what the motherboard looks like,
http://www.ebay.com/itm/DELL-PRECISION-Workstation-470-XC838-Motherboard-with-2GB-/140795014004?pt=Motherboards&hash=item20c8096b74
[Note* Posted for photo reference only. Not for advertising.
Besides, I do not see any VRM's plugged in. Means you get the motherboard only, and no VRM's. You need a VRM ]
What the Voltage Regulator Module looks like,
http://www.thebestpartinc.com/kg229.html
(Again, not for advertising. Click on the photo of the VRM to enlarge)
Notice that your motherboard has two VRM's. This is because there are two Processors.
Apparently the VRM for one of your Xeon processors is bad. (Z-on)
Since it states VRM -> 0, it is for the Processor 0, or in the number 1 processor socket.
What does a Voltage Regulator Module do for a Processor?
Regulates voltage.
A Processor MUST have a steady, 'clean' supply of voltage, AND it must be within the voltage range for the processor.
Since the motherboard uses an Intel E7525 motherboard chipset, it can support Intel Xeon processors, with up to an 800MegaHertz Front Side Bus. (800MHz FSB)
Looking at a typical Intel Xeon single-core processor, with an 800MHz FSB, let me show you it's voltage requirements,
1.287 to 1.400 (DC)
May be just a bad VRM.
However, I would also like you to look at the Electrolytic Capacitors on the motherboard. From what I have seen, those motherboards are notorious about having capacitors go bad.
Visual identification of bad Electrolytic Capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jul 10, 2012
Testimonial: "I just bought Dell precision 670 and used it's VRM to fix mine and it worked alright, but the most astonish issue is that, the old Vrm also works on the new computer(Precision 670) whilst it doesn't work on the old computer (Precision 470). but thanks to the Fixya Team espcially Joecoolvette. "
DELL PRECISION T7400 Blue screen apears multiprocerssor configuration not supported
Since the Precision T7400 has 2 CPU sockets, then assuming there are no "beep code errors" and all the diagnostic lights go off and the power light is green then you probably need to go into the BIOS (press "F2" when the Dell logo comes on during start up) and find the setting that enables multiprocessor support and ensure that multiprocessor support is enabled. If it isn't change the setting so that it is, save the changes and reboot. If it is then it sounds as if one of the CPUs is not functioning properly. Please note that for multiple processors to work, they must be exactly the same.
Feb 15, 2014 | Computers & Internet
When looking into setup, dell precision 690 not showing secondary processor
using my noggin i would say bios does not support the processor you are trying to use, and you will have to change the bios.
link below has useful info bios chip compatibility and so on.
http://www.tomshardware.com/forum/261984-28-upgrade-dell-precision
Sep 17, 2012 | Dell Precision Workstation 690 -1KW Dual...
Windows XP fails to shut down properly an hangs with a blank blue screen.
sometimes that can be cured with a disk optimizer routine
try this one and see how it works for you
May 29, 2012 | Dell Precision Workstation T7400 - Energy...
Nvmini.sys file error screen went blue showing error like non paged sysytem fault.
I sounds like nvmini.sys is a virus or rootkit from what I have just read.
It seems like it is quite tricky to remove. Try searching google for nvmini.sys removal.
If you are not particularly technical, you may be better off paying someone to clean it off for you.
Hope this helps.
May 07, 2011 | Dell Precision Workstation T7400 - Energy...
Can I run a x64 bit os?
Hi
Thank you for your query
Yes you can run any 64bit operating system on here i.e. windows home, professional and ultimate Xp/7
If this has been useful please leave positive feedback/vote/testimonial as this will help me greatly - Thank you again
Feb 18, 2010 | Dell Precision T5500 Computer Workstation ...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
