Question about Hotpoint DY46 Style Line Stainless Steel Electric Double Oven
Neff u1442 double oven trips when put under load
Neff u1421 double oven , both ovens work fine but the grill trips the circuit breaker after 5 minutes of getting hot
you need to check size of breaker the oven is wired too if this is to small it will trip also cable size
Sep 18, 2013 | Neff U1421 Double circotherm Electric Oven
Neff double oven trips rcd when either oven is turned on
your heater elerment has gone in the main oven i had the same problem if you need help takeing it out and see if its the problem get back to me ok
Nov 03, 2012 | Neff U1421 Double circotherm Electric Oven
U1442 main oven not heating
If you are sure there is 220v going to unit, it most likely is element or click / control. If you have a ohms meter, you can test the element
Sep 07, 2017 | Neff U1721 Double circotherm Electric Oven
Neff double oven u1442, main oven thermostat light does not work even though oven heats up. Is there a fix?
If the oven is heating up o/k, then I would suggest that the oven pilot bulb has failed, I have come across this on several occasions, it usually just means replacing the oven pilot light.
Mar 18, 2011 | Neff U1452 Double circotherm plus Electric...
Neff U1721 repeatedly trips RCD. Have replaced lower element 4 times in last 18 months am I likely to have an underlying earth fault, or are "cheap" elements more prone to failure
Sounds more like the power supplying the oven is at fault. Need to make sure that all power is correct from stove to box. Very unusual for that many elements to be going bad.
Feb 04, 2010 | Neff U1721 Double circotherm Electric Oven
Neff U1524 Double oven
Your oven should be connecting individually to its own fuse in the fuse board.
Jan 03, 2010 | Neff U1721 Double circotherm Electric Oven
Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
Fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Dec 19, 2008 | Neff U1721 Double circotherm Electric Oven
Main oven tripping the fuse
probable fault to earth of circular element - gets worse when element hot. you will need a megga to confirm this.
May 22, 2008 | Neff U1721 Double circotherm Electric Oven
Hotpoint DY46 Style Line Stainless Steel Electric Double Oven Logo
24 people viewed this question
Top Hotpoint Ovens Experts
Colin Stickland
Colin Stickland
Charles T Nevin
Charles T Nevin
Jacques Valiquette
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
