How to RESET the Error code "6502" for CANON ip7200 ?
It happened after I changed to a different cartrige.
SOURCE: error code
hi peepz,Just to share CANON MP800 Error CODE 6502:I have been using INKRIS.com CISS system for years now until this stupid problem came up.to further clarify,
1)Lift the Lid.
2)switch off the printer by pulling out the plug.
3)then shift the ink cartS to the right.
4)close lid,plug in power.
5)HOLD DOWN power button then press STOP/RESET button twice.
6)Then press STOP?reset button 4 times.
7)the screen on MP800 will go white.with SPF test mode Idel written on it.
8)then power off and power on again.
THANKS for SAVING MY PRINTER!
Posted on May 19, 2008
pamthegreek
  • 148 Answers
SOURCE: canonmp510 service error code 6502
mp510
Posted on Jul 17, 2008
SOURCE: canon IP4500 service error code
canon pixma 4500 service error 6502
Posted on Mar 29, 2009
SOURCE: Canon Pixma IP600D - error code 6502
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Posted on Jun 10, 2009
pineworks
  • 4041 Answers
SOURCE: error code 6502
This might work
Error Code 6502 appears generally after chaging a cartridge.
Solution:
  1. Unplug the printer.
  2. Remove the faulty Cartridge
  3. Plug in the printer and press and hold power button
  4. Keep it held down. Press Resume twice, and this should reset the fault.
All Best: Pineworks
Posted on Jan 25, 2010
Changed ink cartridge and now have error 6502 - have no clue what that means, but it won't print - yellow and green light alternate flashing
Error Code 6502 appears generally after changing a cartridge.
Solution:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 12, 2011 | Canon PIXMA iP3500 Printer
Canon pixma ip4300 Stoped working, light flashes 19 times and error code 6502 displayed on screen Help please?
Hello
Try
Solution:
All Best: Pineworks
Oct 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
ERROR 6502
Error 6502 (Ink tank position sensor error) the sensor is receiving too much light. Possible causes are:
1. The printer cover is open and the sensor is exposed to the light
2. The ink tank LEDs are busted
3. Sensor or its wire connection to the logic board is busted or disconnected
Solution:
1. Close the printer cover
2. Possible ink tank replacement
3. Change sensor or repair disconnected wires
Sep 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error 6502 canon MP530
Hello
Try it for a canon
Solution:
All Best: Pineworks
Jun 07, 2009 | Canon PIXMA MP530 All-In-One InkJet...
When printer is turned on error code 6502 comes on screen
Solution:
All Best: Pineworks
May 05, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Have error 6502 on my mp510 printer this has happened since i replace the ink cartridge, can any one help this is driving me crazy
Try may work
Solution:
All Best: Pineworks
Mar 30, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Canon PIXMA MP500 - "Error Code 6502"
Try holding the stop/reset button down for 10 seconds to see if the error clears. If it does not repost your error message to the forum.
Jan 28, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error code 6502 on my canon printer
How to RESET the Error code “6502” for CANON ip4300 ?
1, With the printer unplug, remove the ink cart to the right ,
2,Plug in the printer ,Press the POWER button, Do not release the POWERbutton ,and then press the RESUME button twice in succession .Nowrelease the POWER button ,press the RESUME button 4 times .
3,The beeper may sound once ,Then With the printer unplug ,afterthat reset the printer electronics ,open the printer and this processis finished.
Sep 17, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Error code 6502
This might work
Solution:
All Best: Pineworks
Jun 14, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error code 6502 on MP510
why error 6502..........?????
Help me pls.........!!!!!!!!!!!
Feb 26, 2008 | Canon PIXMA MP600 all-In-One InkJet...
615 people viewed this question
k24674
