What's the Cisco router common command?
As I'm new for the Cisco router, I want to know more for the command, and who can tell me the details for the common command?
  • Emma Lee Feb 14, 2014
    well, you are lucky, the bloghttp://ciscorouter1921.wordpress.com will help a lot, the answer for you.
  • 3,320 Answers
Thanks for the update
Posted on Apr 14, 2014
4 Suggested Answers
kvgopi
  • 73 Answers
SOURCE: user manual for cisco 1800
1800 series is a MSR (Multi Service Router) with that you can build a network with voice,data and enhanced security. In selected models Wireless is also available.
Check the manual in the following link
http://www.cisco.com/en/US/products/ps5853/index.html
Posted on Mar 17, 2009
garethmt
  • 116 Answers
SOURCE: UPnP on Cisco router
It doesn't support UPnP, it is a commercial product.
Posted on Aug 21, 2009
  • 85 Answers
SOURCE: I have a 3Com Router,
The commands are different than a Cisco device. Rather than try to list all the commands in this solution I'm providing you a link to the products support page on the HP website (HP bought 3Com a while back). The support site has the manuals, command reference guides, etc for your device. It should be everything you need to get started. Best of luck!
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=12883&prodSeriesId=4235691
Posted on May 05, 2011
Testimonial: "Thanks.."
Problem with cisco 2513 routers
Check what version of software do you have. Do "dir" command and look at the file name. If it contains "K9" in the name, then it has "crypto" functionality, if it doesn't, then you need to find it (however it will be quite a challenge, as these routers are end-of-life for a decade...)
Good luck,
Mike ' CCNP, CCDP, CCSP, CCVP, etc.
Cisco Compatible Headset Adapters for 7940 7960 etc
Mar 30, 2017 | Cisco Computers & Internet
What command will show the maximum bandwidth a
The command is : bandwith ?
will show you the maximum bandwith
Jun 23, 2009 | Cisco 7505 Router
Ethrnet problem for cisco 1841 router?
Hi
You must enter the interface configuration mode and issue the command:
no shutdown
Mar 19, 2009 | Cisco (1841) Router (cisco1841)
Hi all. Now i'm lose IOS of cisco 2691. help me! and give me how to load IOS to Cisco 2691 by tftp. thanks alot
Recovering Cisco IOS Software imagesIf your Cisco router experiences difficulties and no longer contains avalid Cisco IOS software image in flash memory, you can download a newCisco IOS image using one of the following ROM monitor commands:
blank.gifxmodem—(AllCisco 2600 series routers) Use this command to copy a Cisco IOS imagefrom the console, if the computer attached to your console has aterminal emulator with Xmodem capability. See the "Copying an Image from the Console Using the xmodem Command" procedure.
note.gif Note blank.gifDownloadinga Cisco IOS image from a console is very slow. This procedure should beused only in an emergency and is not recommended for normal Cisco IOSimage upgrades.
For the fastest possible download from a console, set the console speed to 115200 bps by using the confreg ROM monitor command. See the "Configuration Register Commands" procedure.
blank.giftftpdnld—(ExceptCisco 2691) Use this command to copy a Cisco IOS image from a TFTPserver that is accessible through the FastEthernet 0/0, Ethernet 0/0,or Token Ring 0/0 port. See the "Copying an Image from a TFTP Server Using the tftpdnld Command" procedure.
note.gif Note blank.gifThetftpdnld command is not available on the Cisco 2691 router. Therecommended method for installing a Cisco IOS image on a Cisco 2691router is from a CompactFlash memory card loaded in the externalCompactFlash memory card slot. See the "Entering Boot Commands" procedure.
P.S.: If this information was helpful, please rate this solution.
Mar 12, 2009 | Cisco 2691 Series IOS
I have cisco router 857 and dont know how to configure
Hi!
You can access the user manual for your router by going to:  http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/857sg_bk.pdf
But simply put,  - You have to enable the web interface in Hyperterminal/Telnet/Terminal - To connect to your router this way, open your Terminal and type the following commands in order:
1) enable (enter password if necc.) 2.) config term 3.) ip http server (this command might also be set to "no ip http server") 4.) exit
After doing the above: 1.) Press Cntrl+Z 2.) Go to Copy, Run, Start 3.) Open your browser and go to "10.10.10.1"
Good luck! -TJ
Nov 30, 2008 | Cisco 857 Router (CISCO857K9)
How can i know the routers commands to configuare a cisco router ? Thanks
Question mark is your best friend if you don't know when what commands you can type, but learning how to configure a cisco router is not a 2 minutes thing and 1 post is far not enough to tell you all about it. A list of commands won't do too much good for you anyway because there are 3 different modes and each has it's own commands and there are lots of commands.
If you want to learn the basics I suggest you to read their most basic book "CCENT/CCNA ICND 1"
Or try out their SDM, that way you can configure the router with good old fashion pushbuttons and check out the commands what it's sending to the router.
Here's a little bit of showaround about SDM:
If this isn't going to help you out I suggest you to post another question where you are specifically telling what you'd like to do and some expert will write down the commands, but you need to be very specific with the details of the network and the requirements and the services you need, wich routing protocol you'd like to use, etc...
Nov 23, 2008 | D-Link AirPlus DI-524 Wireless Router
Cisco roter
All routers can route.
The commands are more than just a few for a proper link, but the simplest answer to the limited information you supply would be:
ip route <destination network> <destination subnet> <ip address of the remote router>
Do that on both ends, and you should be able to ping from LAN to LAN. I think that's what you want?
Nov 16, 2008 | Cisco 2524 Router
Help me plz
cisco routers make use of an IOS software for configurations.
you have to connect the router to a computer system through an hyper terminal program in order to access the router command interface,there is no way you will be able to configure this router without having cisco configurations knowledge.
the steps could be complex/complecated for a novice.but all the same,
after running the hyper terminal program on your computer to connect the router(start-accessories-communication-hyper terminal) make sure you use cisco serial cable or a cat5e roll over cable.
press the enter key once and type 'enable' then press enter,
configure terminal,to take you to a global configuration mode.
i will advice that you should contact a cisco person in your area for help
Apr 23, 2008 | Cnet CN UM56-RS (CNUM56-RS) Modem
Router configuration
i sujject you learn CCNA - cisco certified network associate course ware .. then you can configure most of the routers with slight syntax changes
good luck
Jan 15, 2008 | Actiontec GT704WG Wireless Router...
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
David Payne
David Payne
