Question about Dell Studio Xps 7100 Desktop Computer (AMD AMD Phenom II X6 Phenom II X6 1035T 1000GB/4GB) (EXPDDV1)
Replacing power source
Witch pluggins go where?
    Brigadier General:
  • Dell Master
  • 3,400 Answers
IF YOU MEAN PSU STUDY HOW THE YOU REPLACING IS
MOUNTED AND CABELS LAYD.
Posted on Feb 14, 2014
Hello I have been given 2nd hand a Dynex LCD TV DX 40l130A11 TV from my cusin and pluggin it in is fine and attaching it to cable was okay but it comes up saying no signal. how can I just view the TV?
Hi Rory,
I hope you have chosen the correct input source ie. RF, AV1, AV2, PC or HDMI to which you have connected the cable. Despite choosing the correct input source if the TV says no signal means it is not reading the signal. In that case the main board is defective. A good technician who knows component level repairing can repair the main board. Otherwise you will have to replace it.
Apr 12, 2015 | Dynex Televison & Video
Pluggin headphones into my behringer 2442fx mixer is creating a lot of static coming out of the headphones.
This happens when you have lose earth connection from your main source power supply. Check the earth connections (grounding) which should be available in the mixer, i.e some power cords don;t have earth wire, so change this if you think yours don't have it. Also check the grounding of the other items attached to your mixer, basically grounding is very important to reduce the static shorts. Try changing the power supply source, change to other outlet and check if it is OK.
Apr 14, 2011 | Behringer XENYX 2442FX Mixer
Cant find brake module XL34-2C346BCF150....right side caliper hanging up or slow to release pressure. Has over 200k. Solenoid hangin up????calipers are new. Pulls left when braking and after stop as I...
Pump the brake pedal then go check and see witch caliper is hanging up release the bleeder on the affected one if fluid comes out under pressure and the caliper then frees (wheel would have to be off ground ) the flex hose could be falling apart inside and pluggin up.Replace flex hose.
Feb 15, 2011 | 1999 Ford F150 Regular Cab
My surround sound shut off and sound went to tv as it's output source
try unplugging it and pluggin it back in. and make sure no wires are touching that would make it shut down.
Oct 06, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
When pluggin to the car charger and turn it on. it's a low battery and it keeps turning off. it doesn't charge. garmin nuvi 750.
the battery is defective and needs to be replaced, if the battery is not any good then it won't work even when plugged to an outside power source, that is how this are set up, the battery is not user servicable, u must send it back to Garmin for replacement.
May 26, 2010 | Garmin nuvi 750 GPS Receiver
I have 124 volt going to my element but my stove still dont heat up?
you need 240 volts you need to find witch does not have power by removing a wire then use your meter ground it to the neutral wire on your cord and see witch side is dead.follow the dead wire to the source.good luck!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 22, 2010 | KitchenAid Kitchen Ranges
No power to wii console
Try pluggin the power adaper into a differnet wall socket. Also try pluggin a different device into the socket that the Wii is currently plugged into to test that the socket is good. Make sure all cables are connected firmly including the spot on the power brick. If this does not work then something has either gone bad in the Wii or the power brick is dead.
Apr 20, 2009 | Nintendo Wii Console
I need source code of trial version to add to a software product
witch trail version witch program
ben.pluijm@viveole.com
Apr 14, 2009 | Computers & Internet
Problem with flash pluggin
update your flash pluggin.... go to the pluggins site(adobe) and check for the latest pluggin....
Feb 25, 2008 | Computers & Internet
Dell Studio Xps 7100 Desktop Computer (AMD AMD Phenom II X6 Phenom II X6 1035T 1000GB/4GB) (EXPDDV1) Logo
62 people viewed this question
Alun Cox
