Question about Toshiba estudio 255 Copier
Paper indent - Toshiba estudio 255 Copier
My bjc 1000 canon printer has a probem with the paper feed ? as the printer engaged to feed the paper the paper move to the right hand side and then gets screwed up .thanks
This is very simple. Pull out the screwed up paper back out very slowly. Look at its leading edge for an indent. Lay the paper back on the feeder. Now the indent will line up with the foreign object that has fallen into the printer. It may be a paper clip, staple or pin from a cork board behind the printer on the wall. Unfold a large paperclip and use this as a tool to retrieve the object. Always works.
Nov 01, 2016 | Canon Office Equipment & Supplies
Konica minolta c284 indentaions on paper
Sir mam are you sure it is not happening before fixing does your transfer belt (Shine y looking thing inside the machine when you open the right side of the machine) Does it have only one pic finger in the middle is that where the nick is located. I believe you transfer belt is causing it not the fixing unit. Stop a copy before fixing does the nick move on different copies
Apr 03, 2014 | Konica Minolta bizhub Office Equipment &...
Canon i70 line in center of paper
Something is clogging the paper path. A foreign object may have fallen into the printer causing all the problems.
Feb 20, 2014 | Cannon i70 Printer
Indentations in paper from Brother printer
the fuser unit is faulty. you need to change out this component to correct the problem. you may have found a small part that popped out prior to the problem.
Apr 06, 2013 | Brother HL-4070CDW Printer
Brother MFC 9840CDW When printing using paper from the paper tray, the printer will pull the paper up off the stack of paper from the paper tray but drops it at that point and will not feed it in to the...
Pull the paper out and look at the leading edge. If there is an indent in it then it is hitting an obstruction. remove the cassette and see if you can see anything it may be hitting. If there is no indent then the rollers are not gripping. You should not use alcohol on any rollers. Just use soapy water. Fairy liquid is great for cleaning rollers.
Apr 28, 2011 | Brother MFC-9840CDW Laser Printer
I just want to install a new cartridge.
the grey tray located above the paper tray and below the scanner platform (has an indent in it) is where the cartridges are replaced at. When you pull it down (with power on and connected) the cartridges will move to the center of that opening. There will be an indented "button" that you press to release the cartridge. After you take it out, remove the film from the new cartridge and install it in the same way (number side up)
Jun 10, 2009 | HP Photosmart C4180 All-In-One InkJet...
The letters are not showing up on the paper
Make sure your printwheel is installed with the letter indentations facing the paper, and make sure the ribbon is placed between the printwheel and the paper. Also, check your ribbon to make sure it has not dried out.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Apr 21, 2009 | Brother ML-300 Typewriter
Paper will not feed, some large spring is loose and don't know where it goes
Okay, I figured it out - if you unhinge the paper tray holder and you look at the bottom of it there is a little circular indentation that is where one part of the spring goes. I surperglued it that. Then if you look inside the paper holder you will see another circular type indent that has a tiny little plastic latch at the top of it - it will match up with the one on the paper try holder. I put the superglued spring into the printer and shoved it down with the handle of a comb and a long kitchen knife.
Hope that helps!
Oct 01, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Printing with an a3 hp1208
papers to heavy for printer try another type
Jan 05, 2008 | HP DeskJet 1280 InkJet Printer
Toshiba estudio 255 Copier Logo
14 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
