Question about Manual Units Sphygmomanometer Pressure Monitoring MDS9125LF Medline
Simpson autosensing 512 dryer not heating - Manual Units Sphygmomanometer Pressure Monitoring MDS9125LF Medline
Simpson minimax dryer not getting hot does spin timer works will run for about 2minutes then blows fuse
It is most likely a failed heating element, when it attempts to heat it causes a short, blowing the fuse
Jun 05, 2016 | Dryers
How old is simpson auto sensing 512 drier
You would have to contact the manufacturer and give them the serial number. The date of manufacture is built into the serial number.
May 11, 2012 | Dryers
Dryer lost heat. simpson ezyload 4kg
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Whirlpool GEW9250 Electric Dryer
I have a Simpson autosensing dryer. I moved it and now doesn't dry. It goes but no heat. When I moved it I tilted it by mistake
heatman101][][
Aug 11, 2011 | Dryers
Simpson maxidry 362 dryer not heating, everything else seems ok
Two things to check. First, check for any lint in the screen or lint build up in the exhaust. this will restrict airflow. Secondly, check to see if the heating element is bad.
May 15, 2011 | Dryers
Simpson Maxidry 1200 S Clothes Dryer. Dryer spins, Blower working, but heater doesn't work. I've got the element out & it checks ok. What next please?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Dryers
Fan in the Simpson Sirrocco 500 clothes dryer doesn't work.
It is both easy and cheap! I do believe there is a cover on the back of this model hiding the drive belt for the fan. It has iether broken or come off. If it has come off and lint or something of the like was not the cause it is quite possible that it has stretched and will require replacing =)
Feb 25, 2010 | Dryers
No heat and autosense timer does not shut off. Is this just the thermal fuse or is the element bad?
There is a thermal fuse located at the top of the heat canister that could be bad. The heating element could be bad. The 220 volts power to the dryer could be bad.
You need a volt/ohm meter to check these out. Set the meter for volts. Remove the service plate from the rear of the dryer where the cord connects. Check for 220 volts incoming. Check the wires there to make sure one has not burned loose.
Remove the rear panel to access the heat canister. Turn off the power or unplug the cord. Set the meter for ohms/continuity. Remove the wires from the thermal relay on the top of the heat canister. Touch each meter lead to each of the 2 terminals on the relay. If it reads,it is good.
Remove the wires from the heat element. Touch both leads from the meter to each terminal on the heater. If it reads it is good.
If any part does not read,replace it.
Sep 13, 2009 | Roper Dryers
Manual Units Sphygmomanometer Pressure Monitoring MDS9125LF Medline Logo
20 people viewed this question
Top Medline Vehicle Parts & Accessories Experts
baire
Lawrence Oravetz
 Russ Hill
Russ Hill
Are you a Medline Vehicle Part and Accessory Expert? Answer questions, earn points and help others
