No screen no sound
42LC2DR
LCD DVD HDD problem
Sounds like you may need to replace the hdd in this unit
Mar 19, 2010 | LG 42LC2D 42 in. LCD HDTV
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
My tv has sound but no picture except for a blue screen
My television worked this morning and now only shows a blue screen. The sound works but no picture except for a wavy blue screen.
Jan 22, 2010 | Televison & Video
LG 42LC2DR takes ages to start
Check for bad caps in the power supply.
Jul 24, 2009 | LG 37LC7D 37 in. LCD HDTV
Slow screen and no sound
Could you please specify some things like how big is your hdd & how much memory do you have. These 2 things are very important when installing a new operating system like xp & up.
Sounds like you may need another one of the sound drivers. Do you have the Realtek97 Audio driver?
And is your standby option greyed out when you click start & turn off computer? This will be a video driver issue I'm pretty sure. When you drag a window quickly across the screen do you see it like streaks or what exactly do you mean by "slow screen"?
Jul 17, 2008 | Computers & Internet
I have a 42inch TV LG MODEL 42LC2DR and it keeps saying that the hard disk needs initiliasing even when we have lots of hard disk space available, and you have no choice but to do which wipes all the...
I have the same set and the same issues. I asked LG here in Brisbane the same question, there is a modified connector and cable assembly from the circuit board to the hard drive that fixes this issues on "early" manufactured set. However it is expensive and purchase and for them to "fit" Shame LG do not offer to fix a "production" or "design" issues with a better priced mod kit and fix this once and for all. Let me know how you go in your contrary?
Jun 21, 2008 | LG Televison & Video
LG 42LC2DR
The SATA (data) cable on the HDD could have an intermitantly fault.Also check that you unit has the current software version.
Change the SATA cable or contact your local service center.
Dec 11, 2007 | LG 42LC2D 42 in. LCD HDTV
42LC2DR
You need to press the button on the top right of the control ( the TV button) once and that will allow you to control the tv once again. Problem occurs when you accidently push VCR or DVD button which means remote control will try a different frequency to operate a VCR or DVD that isn't there. Hope this helps.
Aug 18, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
