Question about Sony VPL-EX3 LCD Projector
Lcd projector vpl-ex3 lamp cover problem - Sony VPL-EX3 LCD Projector
welcomejee
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
dw24_uk
  • 97 Answers
SOURCE: I have purchased 2 sony ex3 lcd projectors(one for
you may have to reset the lamp hour meter to get it to work, put the projector on stanby and press the remote buttons, reset - back - forward - reset, (this is the code for a vpl hs20 projector it may be slighty different for your model)
Posted on Jan 14, 2011
caroldon
  • 17129 Answers
SOURCE: Sony VPL-EX3 projector on/off switch
Possible that the lamp is faulty -if the hours have elapsed- check the lamp holder, the fitments.
check also the filters, clean and reset.
Make sure the power supply Unit is not having any poor soldering or faulty components to reduce the voltage output to the lamp thus making it shut down..
Posted on Jan 17, 2011
AJIN G
  • 6694 Answers
SOURCE: I have replaced the lamp
DO the following for resetting the lamp hour
1.Connect the power cord.
2.Press the following keys on the Remote Commander in the following order for less than five seconds each: RESET, Left Arrow button, Right Arrow button , ENTER.
ok
Posted on Feb 09, 2011
SOURCE: How do you turn the
Pressing the On/Off Key for 10 seconds switches on and off the projector.
While on, press the menu key for 10 secods to reset it to unlock.
Posted on Mar 14, 2011
Good Day, I have 3 sony ex3 projectors - 2 of which have an intermittent lamp/cover error where the lamp/cover led blinks and the machine does not light. The problem is still there even after i press...
The small lamp cover dimple that is supposed to activate the protection switch doesnt reach the switch if the cover is slightly curved due to age and heating.
So I put a small dob of silastic on the dimple of the lamp cover and let it set for 24 hours. Then I put the cover back into the unit and all is OK.
In your testing, make sure you are pressing the switch down manually before you power up the unit.
Then the error message is not likely to be a cover error message.
If you still get the error then I would check the integrity of the switch mechanically and electrically. Check that the connector from the switch to the pcb is OK.
Aug 19, 2011 | Sony VPL-EX3 LCD Projector
Sony VPL-EX3 "Lamp cover problem", it wont switch
There is a small switch that detects when the lamp cover is securely tightened down, so that it protects the user from the high voltages, hot surfaces, excessive bright light in the eyes, and damage to the face if the lamp implodes due to old age and overuse.
so check if the switch operates when a toothpick is pushed up and down in the cavity.This model suffers this problem when the cover is slightly warped with old age.
so put a strip of folded paper between the cover plastic protusion that actuates the switch and the switch and secure the cover and see if this is all that is needed to activate the switch properly.
if it now works, you can try putting a small drop of silastic on the cover protusion and wait till it sets over several hours in order to lengthen it slightly so that it reaches the switch properly
Jun 30, 2011 | Sony VPL-EX3 LCD Projector
Comme on RESET LAMP Videoprojecteur SONY VPL EX3 procedure ?
You can reset lamp timer of VPL-EX3 by following procedure.
Connect power cord in wall socket, standby indicator will lit red.
Press following keys on projector remote.. RESET, Left arrow, Right arrow, ENTER
Lamp timer will reset.
Hope this will help.
Thanks.
Mar 22, 2011 | Sony VPL-EX3 LCD Projector
Have replaced the lamp in my sony VPL-EX3 projector and i want to to know how do I reset the lamp hours masembe christophers
Press the following keys on the remote control in the following order for less than five seconds each:
Feb 19, 2011 | Sony VPL-EX3 LCD Projector
I have replaced the lamp in my sony VPL-EX3 projector and it won't turn on how do I reset the lamp hours
ok
Feb 09, 2011 | Sony VPL-EX3 LCD Projector
Sony VPL-EX3 projector on/off switch flashes green then turns red and the lamp/cover light is orange. Does this mean the lamp needs replacing or could it be caused by some other factors?
Jan 17, 2011 | Sony VPL-EX1 Multimedia Projector
I have purchased 2 sony ex3 lcd projectors(one for spares,and one that needed a new lamp)I also have a new lamp!!But it wont work on either machines.All i get is flashing on/off light,then lamp cover...
Jan 14, 2011 | Sony VPL-EX3 LCD Projector
How do you turn the panel lock off on a sony vpl-ex3 lcd projector?
Jan 12, 2011 | Sony VPL-EX3 LCD Projector
Sony VPL-CX61 lamp/cover blink. Power on, it
hi,
your projectors lamp cover may be open. or there is some thing happened (may be contact problem) with the lamp cover open sensing switch. just open the door and close it. and then try again.
ok
Dec 20, 2010 | Sony VPL-CX61 LCD Projector
Need asistent
my sony vpl ex3 will not light up, has a lamp/cover light on all the time can somebody help
Jun 21, 2008 | Sony VPL-EX1 Multimedia Projector
Sony VPL-EX3 LCD Projector Logo
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
