Lennox split ac has e9 fault - Heating & Cooling
Lennox troubleshootingI have a lennox split evaporator on the ground condenser 3 stories upI have 75 psi suction at evaporator and a 25 pressure drop at the condenserneeds a hot gaz ??is this normal lines...
indicates insufficient gas
for gas lines of that length extra gas is required
Best have the system charged by an ac specialist shop as the pressures are not correct and gas is added according to high pressure and suction pressures
Feb 13, 2018 | Heating & Cooling
Error code E9? in godrej split 1.5 ton AC
Godrej 2 ten indoor despily e9 cood
Mar 17, 2014 | Heating & Cooling
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
Error problem e9 in onida 5star split ac
what means of e9 error code in onida split ac ?
Mar 13, 2013 | Heating & Cooling
E9 ERROR IN HITACHI AC
HI
MY HITACHI WAC MODEL for 1.5 lr, DISPLAY SHOWING E9 ERROR CODE. ALREADY COMPLAIND TO HITACHI CUSTOMER CARE, BUT NOT GETTING POSITIVE RESPONSE. NOW CAN YOU PLESAE LET ME KNOW WHAT DOES THAT (E9) ERROR MEANS AND HOW TO RESOLVE THE SAME?.
THANKS
Jul 04, 2012 | Heating & Cooling
How to solv f6 in voltas split ac
F6 error code PCB Display voltas vertis plus.?
Jun 20, 2011 | Heating & Cooling
Onida split Ac shows E9 error
E7 r e9 error what problem
May 22, 2011 | Heating & Cooling
Need Remote Control for Lennox A/C
Try Heatcraft as they deal with lennox a/c units. Go to their web site is www.heatcraft.com.au and you will be able to find your nearest store.
Jun 11, 2009 | Danby DPAC8399 Air Conditioner
Heating & Cooling Logo
161 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
