Question about Lexmark E332n Laser Printer
Printer prints off the side of the page
This printer prints off the left side of the page. It is like as if the margin for a 8.5" x 11" page was set to maybe 9". When I print a Word document, it prints to the very edge of the page, and then drops several characters at the end of every line. See http://i.imgur.com/13ZmmiC.jpg?1 When I print a series of 1.00" square boxes (8 across) from Corel Designer, they print 1.00 inch height, but about 1 1/16" wide, with the far right box disappearing off the page. An other printer prints the squares exactly 1.00" square (measured with a calipers), as well as leaving a margin on the right. This is a photo of the page with a ruler on it, showing the problem. See http://i.imgur.com/NAkPj6Q.jpg I know it's about a 10 year old printer, but it has had very light use, less than 14,000 pages printed, it's a network printer and has always worked reliably. When the problem showed up, we tried an old toner cartridge in the hopes that it was the cartridge, but it shows the same problem with the three old cartridges we have - so I know it's not the cartridge.
    New Friend:
Hp2600n Colour Printer Colou Problms
Posted on Feb 14, 2014
4 Suggested Answers
All Office
  • 58 Answers
SOURCE: Printing off page
Paper tray guides?
Posted on Jun 25, 2007
  • 25 Answers
SOURCE: Lexmark E232
If this model has separate toner and photoconductor then the photoconductor is at end of life and needs to be replaced. Follow the directions that come in the new photoconductor package to install and reset the PC count this is important.
Luck
Posted on Mar 11, 2008
SOURCE: Lexmark T 640 leaving faint black lines on right side of page
replace your cartridge, and all should be fine.
Posted on Apr 01, 2009
Canon pixma print half
That's a problem with print margins in either the software you use or in the printer settings, unsure, check both
Jul 25, 2013 | Office Equipment & Supplies
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
The printer will not print on the half inch left edge of the page.
go to settings and change the left margin to 0.0. if in Word, then file->page setup and set the margins to what you want, left margin to 0.0 in your case.
Sep 02, 2009 | Laser Office Equipment & Supplies
Cannot print avery labels, get message the margins of section 1 are set outside the printable page, or will run thru printer , printing complete get blank page
I assume this error is occuring in Microsoft Word.
  1. Create a new document, with a full page of the label you are having trouble printing.
  2. To see the margin settings of your document, go to File > Page Setup (or Page Layout > Margins > Custom Margins for Word 2007).
  3. Click OK on the margins dialog, and Word will check the settings against your currently selected printer. If a margin is set outside the printable area (usually the bottom margin set to zero), you should see the warning message.
  4. Click the Fix button to have Word change the margins
    to match your printer. You should now see the Margins dialog with the new margin settings.
  5. Click OK.
One thing to watch for- on some inkjet printers, the printable area is narrower than the labels. This will cause the labels to shift to the right on the page and be misaligned when you print.
If the labels run off the right edge of the page display, or are misaligned when you print, an extra procedure is needed.
  1. Undo ([Ctrl]+[Z]) the new margin setting, or create a new page from the label template again.
  2. Select the entire table of labels ([Ctrl]+[A]).
  3. Right-click the table, and select Table Properties.
  4. Click the Text wrapping "Around" option, then the Positioning button.
  5. Change the Horizontal position to Center, Relative to Page.
    Uncheck the "Move with text" option. Click OK to the Table Positioning dialog, then click OK to the Table Properties dialog.
  6. Left-click (or press an arrow key) to "deselect" the table, then go into the margins dialog (see above) and allow Word to fix the margin settings again.
With the labels aligned to the page, rather than the margins, the new margin settings should not cause the labels to shift.
Once you have the margins set correctly for your printer, I would save the empty page of labels to use as a "template".
Jun 29, 2009 | Lexmark P3150 All-In-One InkJet Printer
Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
Jan 08, 2009 | Lexmark Optra T610 Laser Printer
Left side of page cut off printing from Outlook 2003
Have you try to Copy paste the content of Outlook to Word and then try to print.
As Outlook have lesser option to set for printing. And may not possess all the features to print it correctly.
Let me know if I can assist you further.
Regards
Ellin
Sep 24, 2008 | Canon PIXMA iP90 Mobile Printer
Missing left edge
try to change the settings of the printer. maybe your document is on portrate position and your margins.
Jan 31, 2008 | Samsung CLP 300 Laser Printer
Margin problem
Problem---Printer prints email on the very edge of the paper and leaves off the first 3 letters of every word down the edge of that margin. If you have Windows Live Mail forget trying to fix it from there. Clicking File will not give you the page setup option you are looking for. Go to the bottom of the screen, click "all programs", look for and click "Internet Explorer", click File, click "page setup". A screen comes up in which you can change the margins. The left margin is probably set on .25. Change it to .75. Okay. Go back and run a test email.
Dec 19, 2007 | HP Photosmart 7450 InkJet Printer
Paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Jun 24, 2006 | HP Color LaserJet 2600n Printer
Lexmark E332n Laser Printer Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
